Author Topic: Balljoint Cross-Reference - Everything you ever need to know! STICKY Please  (Read 10003 times)
Offline Langbolt
Wow!
This has All the listings with Thread sizes, tapers etc,etc
http://www.moog-suspension-parts.com/Universal_Outer_Tie_Rod_Ends.asp
So for all those looking for Ball Joints for their Aftermarket A-Arms...look no further!
Eg:Look up ES3045RL ....these are common for some using a 16mm x 1.5mm Pitch thread
http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-ES3045RL
or ES2074R
http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-ES2074R
ES2096R are the ones I used for my Burgards that were M14mm x 1.5 Pitch thread.
http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-ES2096R
They're $27ea and they came with a grease fitting
Another 14mmx1.5 is the ES419R
http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-ES419R
For Lone Star's that use the FRAP brand - look here:
http://www.splashndirt.com/pages/en/catalog/index.asp?sopt=opt2&search1=Frap+Ball-Joints&Submit23=GO
« Last Edit: January 01, 2015, 09:13:55 PM by Langbolt »
Offline dirtyd
« Reply #1 on: December 31, 2014, 04:37:09 PM »
first two links not working
87 Tecate4- new project
Offline Langbolt
« Reply #2 on: December 31, 2014, 04:57:16 PM »
Quote from: dirtyd;48262
Fixed :)
Offline dem3500
« Reply #3 on: December 31, 2014, 05:57:23 PM »
That's a LOT of ball joints! Haha very handy for sure.
Offline trx250scar
« Reply #4 on: December 31, 2014, 06:23:30 PM »
That's good Info. Thanks
Offline dirtyd
« Reply #5 on: December 31, 2014, 08:00:06 PM »
I understand that the threads that go into the a-arms are diff. for the aftermarket arms but the stud taper and thread size are different between those listed. shouldn't that be the same. Just wondering if one of those two you  listed could be wrong. I have Burgard arms and will be looking to get some soon and just want to make sure I get the right ones.
Offline trx250scar
« Reply #6 on: December 31, 2014, 08:17:28 PM »
It's been so long now so I cannot remember the exact details but my old lsr standard travel arms needed new ball joints and ended matching it up exactly with an old vw bug part. Just got them from autozone for like $15 each. So I am sure some were in that list there is one for quite a few different applications.
« Last Edit: December 31, 2014, 08:18:14 PM by trx250scar »
Offline Langbolt
« Reply #7 on: January 01, 2015, 11:40:08 AM »
Quote from: trx250scar;48270
Yes you could use the ES419R from a '68-77 VW Beetle.....but its the stud thread that's different. If you want a M14x1.5 thread for the A-Arm and a 12mm thread for the nut....Use this:
Offline The Phantom
« Reply #8 on: January 01, 2015, 03:38:24 PM »
I used the ES419R that I got at autozone for my arms with a 14mm thread 1.5 pitch and they didnt work real well.  The problem I encountered was the 14mm threads were not long enough on the bottom arms for good adjustment.  They were about 1/2 inch shorter than the stock ends I removed making the nut barely get all the way on. There was enough threads on the top A-arm but after adjusting it to match for the bottom there were barely threads left for the nut there either. I red loctite'd just the nuts for a little extra peice of mind but I wont go this route again and Ive also got only about 5 hours of riding and the boots have already ripped.  Steering feels wierd with them too.  It was worth a try for $60 for 4 of them but I wasnt happy with the end result. I think the end needs a slight bend from where the ball joint and the threads begin also. Just figured I chime in with my experience with them.
1988 TRX ESR 350 PV +4 STROKER (363)RACE DOME* ESR TRX9 PORT AND TRX5B PIPE & SILENCER*38mm Smartcarb*V-FORCE 3 REEDS*CR500/400EX CLUTCH MOD*ESR BILLET KICKSTARTER,SHIFTER,BRAKE LEVER, TEMP GAUGE*GPI RADIATOR & HOSES*LSR +2 A-ARMS*LSR STEERING STEM & CLAMP*LSR CARRIER & AXCALIBER AXLE*ITP SS112 RIMS WRAPPED WITH RAZR 2\'S*TRIPLE RATE WORKS FRONT SHOCKS W/REZ*AC RACING NERFS*DG FRONT BUMPER*LED TAILLIGHT
Offline dirtyd
« Reply #9 on: January 01, 2015, 06:38:30 PM »
Thats the problem I have now is that I don't like that the nut is barely threaded on. SO where can you get ball joints that are meant for the 14mm  arms?
« Reply #10 on: January 01, 2015, 07:23:45 PM »
Quote from: dirtyd;48292
I too am looking for ball joints for my Laeger a arms.  hoping this helps:
http://trx250r.org/threads/1688-Laeger-a-arms?highlight=ocap
looks like we need the ocap brand:
http://r.search.yahoo.com/_ylt=A0LEVwzU5KVUNooAdrZXNyoA;_ylu=X3oDMTEzcWZiaWE4BHNlYwNzcgRwb3MDMwRjb2xvA2JmMQR2dGlkA1NNRTcwM18x/RV=2/RE=1420186964/RO=10/RU=http%3a%2f%2fautoplicity.com%2fproducts%2f3292459-ocap_311415812cit_steering_tie_rod_end.aspx/RK=0/RS=s7.Zj34Nrmt9RF8XNLCc_4NJ9Sc-
thanks Lanbolt and bnau267
I'm ordering the ocap part (s) next week.
