Author Topic: Cascade Innovations CSFX Silencer  (Read 11181 times)
« Reply #15 on: May 02, 2015, 08:46:48 PM »
Tony to the rescue!!!!  thanks in advance
Online havinnoj
« Reply #16 on: May 04, 2015, 12:35:26 PM »
Nice presentation Tony!
« Reply #17 on: May 04, 2015, 01:03:05 PM »
I was working on stingers all weekend for the casacde. I have some 4" tube but want to get a new piece of 4 1/2 in here. I may have a guy to do these with me.
89mm  Mini tooth Shearer in frame pipe chromed! Mounted with Cascade QUIET[/
« Reply #18 on: May 05, 2015, 03:27:06 PM »
Quote from: Rupp250;52430
How much??????????????????
I cannot get the thin wall aluminum tubing from local suppliers so I have to get it on line. They come in 84" lengths. So you can make exactly 6 silencers with none left over. Ordered material today and will proly get in a week. I have a guy who can draw this up in solid works so I can get prints made for machine shop estimates. Won't know how much they will cost until everything is done. I have to research duplicating the new Cascade innovations star end cap. If anyone has one I could use some pics or I will have to order one. Banshee silencers are only 3 1/2" or 4" in diameter.
« Reply #19 on: May 05, 2015, 03:32:10 PM »
Quote from: Pumashine;54083
ur making them yourself, draw up a new fancy design of your own instead of remaking theirs :)
« Reply #20 on: May 05, 2015, 03:35:15 PM »
Quote from: JesseA420;54085
I was researching the idea how its put together. Don't want to reinvent the wheel.
« Reply #21 on: May 05, 2015, 10:02:15 PM »
Tony did you try Team Tube off Airport way in Portland? http://www.teamtubellc.com/en.aspx
« Reply #22 on: May 06, 2015, 10:01:50 AM »
Quote from: Skeans1;54104
I can try today. I also ordered the star endcaps from Cascade and some packing material. I have a program for punching the core I developed 10 years ago. The perforated tube anyone uses rattles around and falls apart. There needs to be a solid part at each end for the core for it to not destroy itself. Years back I was riding my sons bike on the dunes. I stopped to talk to Corey. He asked why my Cascade was so loud. The core had fallen off the 3/8" lip at each end and was laying at the bottom of the canister.
« Reply #23 on: May 06, 2015, 10:04:52 AM »
They have had everything I've needed in the past. How much for one of the silencers?
« Reply #24 on: May 06, 2015, 11:33:58 AM »
Quote from: Pumashine;54126
.................. The perforated tube anyone uses rattles around and falls apart. There needs to be a solid part at each end for the core for it to not destroy itself. .............
The solid band at each end will help but may still fracture if you make the cores out of 20 or 24 gage material.
I make my cores out of 16 and 18 gage material.  Using this material makes the silencers heavy, and are time consuming to build, but the cores are bullet proof.
« Reply #25 on: May 06, 2015, 12:22:42 PM »
Quote from: Jerry Hall;54129
Exactly Jerry, these are from 18 gage. The one on top is stainlass and the one on the bottom with tig welds is mild steel. Pain in the azz to make out of stainless to get such a small diameter. I bent them close with a large radius on the press break then form them round with hose clamps around an 1" solid round bar with a rubber hammer.
Offline pantera1975
« Reply #26 on: May 09, 2015, 11:29:26 PM »
Id be interested in 2-3 for ATC but they must have a spark arestor for Wisconsin.
Offline Bowtie316
« Reply #27 on: September 23, 2015, 11:06:40 AM »
I'm definately interested as well.  I have been planning to fabricate one myself for awhile but just haven't gotten around to it.
Online havinnoj
Re: Cascade Innovations CSFX Silencer
« Reply #28 on: May 16, 2018, 01:19:58 AM »
Bumping this up
Online jcs003
« Reply #29 on: May 16, 2018, 05:02:23 AM »
i would be interested in one.
what is your solution for the end that mates with the stinger?  Is the idea to use your current silencer end?
