Author Topic: 450R Swingarm on Stock 250r Frame - Need some dimensions  (Read 11113 times)
Offline troybilt
« Reply #15 on: March 04, 2014, 09:07:43 AM »
I can make a link not a problem, I have full CNC machine shop at my disposal.  The biggest issue you will have to have a shock setup for this link, which can be big $$.   I don't see many, (1 or 2 guys)  that will spend the money for a shock correctly setup for a long travel linkage.
Maybe Andy can help us with the shock setup and its limitations.
Elsinore 496cc Saber
« Reply #16 on: March 04, 2014, 09:27:06 AM »
Quote from: troybilt;27690
Very true, Troy. I honestly didn't mean that you couldn't make the link. I know better than that. I was hoping more so that maybe Andy could chime in about the best way to make a shock for this. Remember, even a no link and cr500 link shocks were new and unheard of once.
Offline JoePA
« Reply #17 on: March 04, 2014, 09:28:01 AM »
The key to making this work, for the majority, is designing a link that the factory rear shock can be used.
Offline troybilt
« Reply #18 on: March 04, 2014, 09:30:54 AM »
Quote from: JoePA;27693
Honda already designed that linkage, LOL!..  I hear ya.
Also the CR500 and no link took months of shock development to get it right, also big $$.
Offline JoePA
« Reply #19 on: March 04, 2014, 09:45:17 AM »
the factory 250R rear shock. I know there are no freebies and maybe this is a pipe dream.
What if a bracket was made to move the mounting point on the swingarm forward to the same measurement as the 250R?
« Reply #20 on: March 06, 2014, 11:13:45 AM »
Any further developments?
Offline troybilt
« Reply #21 on: March 06, 2014, 11:27:00 AM »
Not sure where to take it from here to be honest, when I start building another bike I'll do some testing on my own.  I don't expect anyone to go out and drop a grand on a new shock built for my linkage for testing and I don't see the point in designing one for the stock length shock either.
« Reply #22 on: March 06, 2014, 11:42:20 AM »
Andy, how difficult would it be to take an aftermarket shock set up for a standard link and set it up to be 17" long instead of say, 16" long?
Troy, you said that this 17" length shock could be obtained by using the 250r standard link front with an 08 TRX 450r link correct?
Offline troybilt
« Reply #23 on: March 06, 2014, 11:51:57 AM »
I would have to work with Andy cause he would need the full compressed length and the full extended length, plus the progression ratio curves, force curves etc..
But what I calculated was with a stock 250r frame, stock 04 450r swingarm, 08 dog bone, and a new link that I designed.  This is for a total length shock of 17", I can go higher but you lose progression.
Offline JoePA
« Reply #24 on: March 06, 2014, 12:06:57 PM »
troy, how would the numbers work out if you move the mounting point on the stock 04/05 swing arm forward, I think 1" and used all 86 250R shock,  linkage and dogbone measurements? If my guess is correct then it shoudl be the exact same progression rate as stock 86.
Offline DOUGLAS
« Reply #25 on: March 07, 2014, 06:38:58 AM »
my attempt to use a 450 swinger was met with many as saying it wont work and the geomitry is all wrong you are wasting your time. and this information was coming from some reputible and respected builders and suspension guys. as it appers on paper it would not work. i bought an 06 swinger and tried different linkage set ups till i had this. when i used an 06 swing a 87 front linkage and a 06 rear linkage i had to put the rear 06 linkage in buy spinning it a 180. it droped my ride height by 1/2 inch. this was all bench tested. i assembled this on my bike. i posted my findings with photo's of the articulation of the componets. this is posted on .com. another member who has been ridding r's tried this set up and left feed back that it performed flawlessly. to many members who buy and sell and have these componets. if someone can assemble this set up as a mock up and try swapping out the linkage parts it would be an easyier option. there were many who said the 450 front shocks made the bike sit higher and it would not work on paper. but it does work with + 2 +1 a arms and revalve the shocks. so to get the long travel set up to work on paper may prove to be difficult. try old school bolt it up and try it out. if i had a long travel shock then i would try diffrent linkage parts till it worked. note to assemble the linkage parts some mods are required as they don't just bolt right up. will need spacers and such.
Thank you
Douglas
LED 363 87 stock frame
Offline andy@maultechatv
« Reply #26 on: March 11, 2014, 08:08:44 AM »
Sorry everyone, I've been super busy in the shop lately and haven't checked this site.  You are more than welcome to send me a PM and let me know anytime you need my input and I should get the PM in my e-mail which I check once a day at least.
The way they used to figure out a setup with a new linkage design or new bike was to buy a bike or take one on loan and start playing with it.  These days it's way easier.  I can get you at least 90% there with simple math.   We've done the testing for the valving for each spring rate so I just need you to throw a known spring rate on your shock with the linkage you want to run and give me a sag measurement.  As for correcting shock lengths its also fairly easy on an aftermarket shock.
Troy, I would try to design a linkage that has the lowest starting leverage ratio possible in order to run the lightest spring rate which will give you the longest shaft travel.  It will be more like the YFZ or CR500.  Sometimes you will run into situations where the shock travel is too long and there's no way to get the compressed shock length short enough due to hitting the shaft up inside the body of the shock!  If you get the progression where you want it you should be able to use whatever shock lengths you want by moving 1 of the holes into a different location!  So I would start with a known shock (maybe a stock YFZ if the reservoir will clear)
Offline sdxp787
« Reply #27 on: September 09, 2014, 10:56:52 AM »
Quote from: troybilt;27472
Can someone measure your frame. Need the vertical and horizontal distances from the pivot to the upper shock mount and lower linkage mount on the frame. I don't have a torn down frame. I scanned the 450r swingarm I can lay this out and see what we we have. Calculate leverage ratios, shock lengths, etc..
I do know that the linkage mounting point to the frame for the 86 is different than the 87.  If you would like, I have an 86 frame, bare, and can take the measurements you want.  Maybe the 86, being different, is the one.....
2013 IXCR Senior B Class Champion
2007 TRX450R XC ready
2006 TRX450ER XC ready
1986 TRX250R (XC build in progress)
2007 Honda Rancher
2007 Yamaha Wolverine 450
1998 Suzuki LT80
1984 Yamaha PW50
2004 Honda R12X
1996 SeaDoo XP
« Reply #28 on: September 09, 2014, 07:33:17 PM »
Quote from: troybilt;28004
All it would need is a longer shaft to make it longer but have the same compressed length.
