Author Topic: Antifade. Will a 400EX or 450R one work?  (Read 1958 times)
Offline JoePA
« on: March 18, 2014, 07:24:16 AM »
I found an antifade from a 400ex and I was wondering if this will work on the R? How about a 450R Antifade? I know you can use a 400ex axle in the R so i figured this may work as well.
thanks!
« Reply #1 on: March 18, 2014, 11:19:36 AM »
They will all work depending on what axle you're running and the number of splines. Also 450R antifade will have 3-bolt design. 250R is 4 but not sure about 400EX
« Reply #2 on: March 18, 2014, 11:32:33 AM »
The 450r one will work but I think you have to use the 450r rear brake components for it. Check out the 450R rear brake conversion, which I thought you were running already? Don't know about the 400ex one.
Offline JoePA
« Reply #3 on: March 18, 2014, 11:45:08 AM »
Yes, I'm running the 450R brake conversion but its been so long I'm not sure what components are 250R, 450R or 400ex!! LOL Ill have to check tonight. The axle is an LSR for a 250R that i know.
