Author Topic: APT smart carb  (Read 21426 times)
Offline 363 stroker
APT smart carb
« on: July 03, 2013, 11:35:39 PM »
I think I am going to pull the trigger on one of thier billet versions for a 363 sphynx. Tell me why I shoudn't.
LSR 363 R
Laeger 250 R
Offline motofool250r
APT smart carb
« Reply #1 on: July 03, 2013, 11:57:06 PM »
DO IT! only if you can post the results =)
Hybrid Stable
443cc LSR/Roll/Stellar Duner
363cc Backup Duner
In progress JP no-link Duner
Next bike now loading.....
Offline 363 stroker
APT smart carb
« Reply #2 on: July 04, 2013, 12:05:09 AM »
Man I have no problem posting results but I have a brand new engine so I have nothing to compare it to.  But from what I read it sounds like the next best thing to sliced bread.
LSR 363 R
Laeger 250 R
Offline oldschoolr
APT smart carb
« Reply #3 on: July 04, 2013, 12:08:54 AM »
I can tell you why you should.. I have one on a 363 also , pro x not a cpi though. I have rode mine about 6 times now the latest a couple of weeks ago with rblack  from the other forum.  I know people are probably tired of hearing about it but  I love mine. I got the 40mm and it has worked every bit as good as apt claims it would. So far every ride it has ran perfect, not a single bog or miss and this last ride we rode mx. It was probably high 80's or low 90's. Before when it got that hot I was changing needles and jets.
Offline 363 stroker
APT smart carb
« Reply #4 on: July 04, 2013, 12:21:24 AM »
Thanks oldschoolr, I was following what you had going on, and everything else I have read I think I am going to order one.
I will def give a ride report.
LSR 363 R
Laeger 250 R
Offline oldschoolr
APT smart carb
« Reply #5 on: July 04, 2013, 12:30:13 AM »
I hope you have as good luck yours as I have with mine. Definitely give us a ride report im curious what someone else thinks about it on a R..
Offline Wolvman99
APT smart carb
« Reply #6 on: July 04, 2013, 04:13:57 PM »
Was it hard to get tuned at first or just bolt on an go ?cast or billet ? Price ? Do you need different needles for major temp changes or for different size motors ?
Offline DOUGLAS
APT smart carb
« Reply #7 on: July 04, 2013, 04:18:47 PM »
keep an eye on ktmtalk they have a lot of info on there on the smart carb. keep us posted
LED 363 87 stock frame
Offline 363 stroker
APT smart carb
« Reply #8 on: July 04, 2013, 04:40:57 PM »
Quote from: DOUGLAS;447
From what I read on there and what Oldschoolr said I think I am sold.
LSR 363 R
Laeger 250 R
Offline oldschoolr
APT smart carb
« Reply #9 on: July 04, 2013, 04:44:49 PM »
Quote from: Wolvman99;445
All I did was bolt on and go, mine is the billet 40. It started right up, I played with the low speed adjustment a little and set idle but that was it. They do have a metering rod that can be changed if needed. But tuning is  a thing of  the past for me now because it always runs perfect. Rblack doesn't  know this yet but the next time we go ride I'm gonna put it on his esr 310 just to try it.
Offline Wolvman99
APT smart carb
« Reply #10 on: July 04, 2013, 05:02:57 PM »
Do you use the same throttle cable as p w k ? Intake and air box boot stock size?
Offline oldschoolr
APT smart carb
« Reply #11 on: July 05, 2013, 01:31:14 PM »
[ATTACH=CONFIG]146[/ATTACH] It uses the same cable as a 38/ air striker and is pretty much the same size.
APT smart carb
« Reply #12 on: July 05, 2013, 04:35:10 PM »
Quote from: danhung11;764
Nice thread. I'm really interested in these carbs.
I am with you on this one Dan, interesting to see the results on some of these hard to jet BB's.
Offline oldschoolr
APT smart carb
« Reply #13 on: July 05, 2013, 07:05:14 PM »
Dan I've already paid for a room from the April trip that I couldn't make. Lil Sahara is letting me just move the dates rather than losing my money. As soon as everyone settles on a date im gonna try  to go.  I have someone  to work at the shop now and it's after my busy season.
Tony that is another reason I got this carb because the last time  I went  to Lil Sahara I never did get it jetted right, I spent half the  time changing needles and jets.
APT smart carb
« Reply #14 on: July 10, 2013, 07:25:52 AM »
im real close to buying one.  kevin at lectron said the issues im having with my carb is my problem.  he fails to admit his carb isnt infallable.  thing leaks and he wont rectify the problem.  he keeps saying its my engine or electronics.
