Workshop
The Mad Scientist
Something Im working on.
Pages:
Topic: Something Im working on. (Read 14493 times)
mrtwidster1
Reply #15 on:
December 15, 2014, 12:33:21 PM »
Just a quote from the article you referenced
The Future Of Leds
Light emitting diodes may well be the real future of multi-purpose and off-road lighting. For applications where the light is made "to be seen" (tail lights, brake lights, etc.) they offer excellent visibility in signal colors. But, in applications where they are used to "see" they can't yet match the sheer illumination power of HID lights.
http://www.fourwheeler.com/how-to/1007or-exploring-halogen-hid-led-lighting/#ixzz3LzNTjOWA
Follow us: @fwmag on Twitter | fourwheelermag on Facebook
Rupp250
Reply #16 on:
December 15, 2014, 12:38:53 PM »
That article is from 2010. I have LED's on my truck, my buddy has them on his Rzr, I have ridden other atv's with them. They work just as well as HID's now.
True, when they first came out the housing didn't project the light as well. Now they do.
DUNER -86 250R Flinstone
mrtwidster1
Reply #17 on:
December 15, 2014, 12:48:07 PM »
You are absolutely correct!
They have made great advances in LED tech. I wanted to use a one bulb design in each light that I could afford and give me the light housing dimensions i was looking for. These HID's meet what I'm trying to accomplish. Like i said before I am trying to get a certain look with my build. But I want everything to be functional. Does not have to be efficient or even practical.
Thanks again!
mrtwidster1
Reply #18 on:
December 15, 2014, 12:50:21 PM »
Quote from: Rupp250;47660
That article is from 2010. I have LED's on my truck,....
Are they just one LED per light or multiple?
Appreciate it!
Rupp250
Reply #19 on:
December 15, 2014, 12:59:29 PM »
I have these in the stock fog location on a F250. I'll take some pics tonight for you. They are in a spot configuration. I got a cheaper(Chinese) knockoff for the ATV in a fog pattern.
http://www.4wheelparts.com/Lighting-Lighting-Accessories/Dually-Series-Spot-LED-Light-Set-of-Two.aspx?t_c=14&t_s=448&t_pt=4242&t_pn=RIG20221
On a side note. do you have a lathe or easy access to one?
mrtwidster1
Reply #20 on:
December 15, 2014, 01:06:18 PM »
Thanks! Yes I have access to a lathe. That is how i modified the pulley on the axle nut.
Rupp250
Reply #21 on:
December 15, 2014, 09:41:05 PM »
Here are some pics for reference. The fence is probably 500ft away. The one is with the brights on and the other is with the LEDs.
Rupp250
Reply #22 on:
December 15, 2014, 09:42:14 PM »
Leds
mrtwidster1
Reply #23 on:
December 16, 2014, 12:16:00 PM »
I researched many lights. Led has come a long way no doubt. Thanks for the Pics as well as the input. It is appreciated.
mrtwidster1
Reply #24 on:
December 16, 2014, 12:32:16 PM »
One note here also. If I could have found a comparable alternator that had smaller dimensions. I would have used it. Of course the the ac voltage will be run through a regulator rectifier and converted to dc.
Also, no more than I will be using the lights I could have used just a battery but I just wanted to try something different.
Last Edit: December 16, 2014, 12:36:39 PM by mrtwidster1
MANIAK
Reply #25 on:
December 17, 2014, 11:46:49 PM »
I like your design. Another thought that I had but haven't tinkered enough yet to get around to it was to mount the alternator to the swing arm but in line with the chain. I was thinking of using a toothed sprocket for the alternator pulley and a spring to apply tension. Basically using the chain as the belt.
I have a friend with a crf 450 hybrid. He had the stator re-wrapped and it can now support 250 watt's. I think he used Ricky Stator.
On my R I run a Ricky Stator high output and I prefer it over the CR ignition. (Mainly because I ride a lot at night.) The performance gain just wasn't a fair trade-off.
mrtwidster1
Reply #26 on:
December 18, 2014, 07:46:08 AM »
Originally I was going to run it off of the chain. Once I started studying out the mechanics and seeing that i would have to apply tension to allow for the pivot arch of the swing arm, I decided to go this route because I was concerned that the chain method would be high maintenance. At my age, I don't need anything "HIGH MAINTENANCE".
mrtwidster1
Guard
Reply #27 on:
December 23, 2014, 06:11:04 PM »
ytman
Total likes: 15
Reply #28 on:
December 24, 2014, 10:26:16 AM »
This is cool. Are you worried about the tension from the belt "adjusting" the axle nut while it's turning?
mrtwidster1
Reply #29 on:
December 24, 2014, 06:58:25 PM »
The OEM lock nut is locked against the pulley and the pulley is recessed over the primary nut housing. The pulley acts as a spacer so there is no loss of locking force of to the lock nut. I do have a concern about the pulley being aluminium but it is aircraft grade. If i need to I will make the primary nut a squeeze type lock. Just experimenting now. Being left hand threaded may help keep it tight.
I appreciate your input.
Pages:
Workshop
The Mad Scientist
