Update:
So I shimmed up the DGH needle with two washers, the distance of what would be a 6th notch, to richen it futher. I bogged a lot from a rich condition, from 1/4 to 3/4 throttle, and the 162 main even seemed to rich bog a bit with this setting.
So, knowing that the DGH needle had a slight lean bog in the middle position previously, and ran good, but a bit flat at the bottom 5th position, I tried the 4th position, which I hadn't tried before. Took it for a spin, and this seems to be the sweet spot! It ran like a raped ape, and the needle seemed about perfect there! Maybe the 1/8th to 3/8th throttle position seemed a touch lean, but the rest felt great! The 162 main was a bit rich but rideable.
So, I am getting there. If I could find a needle, that would be a touch richer in the 1/4 throttle area than the DGH, and the entire needle a notch shorter than the DGH, so I could run in the middle notch instead of the 4th notch, I think I would be dialed in! Any needle suggestions for this situation?
Thanks for all the help guys, this is exciting, to finally get this bike ready to ride!
Got my rear Hipers that came with it installed too!
