Workshop
Suspension and Chassis
400EX spindle onto a 86?
Topic: 400EX spindle onto a 86? (Read 1505 times)
Rupp250
February 17, 2015, 10:22:12 AM »
What does it take to do it correctly? I have 2 sets of 400EX spindles sitting here that I could use. Plus I have 2 86's. Perfect match, right?
DUNER -86 250R Flinstone
Burns363R
Total likes: 49
February 17, 2015, 10:53:15 AM »
You must either use 400ex or yfz calipers, or buy the 400ex/250R adapter brackets for the calipers.
You must run 400ex hubs, or if you want to use 88/89 hubs you have remove or install the tapperd spacer between the bearings.
TRX 370R 86- Laeger Std,ISF-No Link Swinger, JD MGC LT Arms) Motowoz Shocks, LED 370/350D pipe, 38 A/S Carb, 200w OEM Ignition
Rupp250
February 17, 2015, 01:52:38 PM »
Where are these said caliper brackets? I'll have to look into the hub situation because one bike is stock and the other has LSR's. Not sure which year lsr though.
Burns363R
Total likes: 49
February 17, 2015, 01:56:04 PM »
http://www.ebay.com/itm/trx250r-front-brake-caliper-adapter-brackets-400ex-spindle-trx-250r-brakes-blue-/231461565824?pt=Motors_ATV_Parts_Accessories&hash=item35e42f3580&vxp=mtr
I think i saw some used the other day on facebook, not sure they where any cheaper. They are an expensive option. Cheapest is to do the YFZ caliper that bolts direclty to the 400ex spindle. Gives you dual pistons, and much cheaper. I run 400ex spindles on both my 250R's and have the adapters to use the stock calipers. No complaints here.
Hawaiiysr
Total likes: 88
February 19, 2015, 12:54:39 AM »
Steve was selling the adptors. They have since been sold.
Workshop
