Author Topic: Cascade Innovations CSFX Silencer  (Read 23121 times)
« on: March 18, 2015, 07:28:01 PM »
Called cascade today. They have no more big bore silencers and no plans of making more.
« Reply #1 on: March 18, 2015, 08:38:34 PM »
That sucks, is it for a LED pipe?
« Reply #2 on: March 18, 2015, 08:53:15 PM »
Ya a lrd pipe. Was looking into it just in case the lrd silencer I'm getting has a little more bark than I want. I already got tubing prices to make the stingers. Wonder if any one with a cascade would be willing to take it apart and take pictures. Shouldn't be to hard to make something similar.
Offline Sand_Blaster
« Reply #3 on: March 21, 2015, 02:49:40 PM »
Cascade brings a guy in to make silencers & stingers for them. You would just have to leave your quad there for a week or so. Did they say you could do that or just quit all together on the bigbore silencers & just making the smaller ones?
87 Trx250r & 99 Banshee
« Reply #4 on: March 28, 2015, 10:58:23 AM »
Got one BB all apart. Lil more complicated than just welding the base and installing the end-cap. Front and end cap look to start off at .750" thick. They get machined to 1/8" at the out side. Oring seals front and back. The inside has the mount for the core at each end. Of course the end has an turn down insert machined with a press fit. I am gonna get the 4 1/2" OD tubing in and get some prints drawn up for the end-caps. If you saw the new style end-caps and have any idea how they operate you might let me know. I can call and discuss any options if anyone is interested in designing something that is economical and keeps the noise below the legal 95 db limit here in Oregon. The tubing starts at about $15. The end caps are proly gonna be around $20 each. The frame mount is easy for me to fab. Then I gotta find some who can weld aluminum with out breaking the bank.
« Reply #5 on: March 28, 2015, 11:01:56 AM »
Wonder if Pete would do the welding or not
cascade silencer
« Reply #6 on: March 28, 2015, 11:03:06 AM »
so you are going to be trying to make them now tony. if so I'll be interested
Offline patman13mia
« Reply #7 on: March 28, 2015, 02:06:59 PM »
Hey tony i am very intrested also!! Are you fabing all this stuff up then selling to us to weld up? If so ill buy one maybe 2
Offline jafa0
« Reply #8 on: March 28, 2015, 08:14:03 PM »
I almost bought 1 of the last 2 silencers Cascade had 6 months ago or so. I would be interested in one, or the parts for a DIY if you decided to make some. My TRX5/ FMF Powercore is about 96dB at idle. 103ish at 3500 rpm.
\'88 TRX250R Hybrid Engineering 344R "Duner"
ESR Cyl  TRX11 cm pipe, w/ custom quiet silencer
Lonestar A-Arms and swingarm
Maultech - Axis rear GT front shocks. Thanks and RIP Andy
Offline Rupp250
« Reply #9 on: March 29, 2015, 09:31:18 AM »
Tony, if you make these put me down for 2. Would be even better if the end had a spark arrester screen set up. DIY or welded up don't matter to me.
DUNER -86 250R  Flinstone
Offline big_R_bore
« Reply #10 on: March 29, 2015, 09:16:06 PM »
do yall have a picture of one of these silencers?  im just curious what they look like.
« Reply #11 on: March 30, 2015, 11:57:52 PM »
Quote from: big_R_bore;52350
They are 4 1/2" in diameter and 14" long. I made my own core as Cascade cut perf tube that left raw ends. Eventually these raw ends break apart and your core falls to the bottom of the silencer. I spent much time building these cores as the holes are not in a straight line. This helps with sound absorption.
Looking down the inside you can see the front end-cap. It starts out 3/4" thick and is turned on the lathe to leave a 1/2 spout that the core rests in. They came with 2 mounting holes for the stinger, I added 4 more.
The rear end-cap has been turned down to fit precisely the 4 1/2" canister. It has a turn down pressed in and o-ring cut in for sealing. Has 3 equally spaced threaded mounting holes. The canister has clearance holes for the threaded end cap. It uses three 5mm screws to hold it in.
The font end-cap has a 1 1/4" hole with a o-ring cut for the seal. The 1 1/4 hole is used as a through hole for the big bore pipe. Big bore stingers are 1 1/8' ID 1 1/4" OD
I will post the stinger set up next
Offline Rupp250
« Reply #12 on: March 31, 2015, 09:29:47 AM »
How much??????????????????
« Reply #13 on: May 02, 2015, 01:45:39 PM »
Tony, when you have time can you please post a pic of the stinger set up
Thanks
« Reply #14 on: May 02, 2015, 08:17:32 PM »
Its funny you should ask that as I am working on 3 stingers this weekend for the cascade silencer. I will get some pics going and explain the big bore process.
