tbone, originally yes I was going to follow the same train of thought with the 250r airboxes. The problem is the subframe rails are angled in, so part of the box has to be below the subframe and the rest has to fit in between. Unless I chop it up and have a ton of welding... I decided to keep it somewhat simple. What I can do is offer a package so if you want to run an eliminator style, you'd just have to swap to the bracket. I tried to do a similar lid, but the lid can't be flat like I was able to do on the 450r. So far the R has been far more complicated to do an airbox for, even more so than my YFZR setup.... however, I'm not complaining, I like the challenge.
I noticed the difference with the subframes too. I'll never ever run an eliminator setup so you do what you want with that. Lol
If I back off from using the S&B filters, (which are really good filters!!)... there is more room to work with if I stick with the standard 250r filters. I might see if S&B can make a custom filter for me that is similar in size to the standard 250r filters.
Would custom filters be more difficult to obtain in the future? And how fast could we get a filter if needed in a pinch?
It would be nice to be able to go to any online store and buy the type of filter (foam, K&N) that is desired. Whether that's a 450r or 250r filter.
How significant is the difference in flow capabilities between the 450r and 250r filters? I imagine if you're in big Sphynx or Puma territory it would be greater
