I've got both bikes and a radiator out of an R, I have seen fans that were coolant temp driven before just can't remember where off hand.
Mike is on here [MENTION=486]hontrx265r[/MENTION] what about a 450 fan?
i know the trx450 fans have a temp switch. that is what i plan on running along with the 450 over temp light or an electronic display of some sort so i can monitor it better.
What I'm taking about is a heat energy driven fan the warm or hot coolant actually drove the fan.
What all do you want to know for if a 450 fan will fit the R radiator? Just measurements? Voltage?
i want to know fittment. i know the arens has different dimensions on the two bars that are behind the radiator and go up to the upper steering mount part of the frame. ive read that people with stock frames are using a ltz400 fan but i had one of those in my hands and there was no way it would fit.
I can get you the measurements if that helps any
Sure that would be great. Thanks!
He probably needs to know thickness Jared
ok thanks for the info. i dont have a stock frame............ill get it figured out. thanks for the help
