Author Topic: Alternatives to Laeger a-arm bushings  (Read 7004 times)
« on: November 18, 2016, 07:16:29 PM »
Was doing a search for bushings because Laeger wants too much for them & found this older thread on atvriders. Hopefully [MENTION=150]Langbolt[/MENTION] can chime in with some info: http://www.atvriders.com/vbb/showthread.php?490863-wtb-laeger-a-arm-bushings
Offline jwraymond6
« Reply #1 on: November 18, 2016, 07:20:34 PM »
Following this thread I have the older arms that used the smaller ID bushings
Offline JohnTabata1
« Reply #2 on: November 18, 2016, 07:27:48 PM »
Post pic of bushings needed
Offline Langbolt
« Reply #3 on: November 18, 2016, 08:03:30 PM »
Quote from: broken1;70833
If you can measure the ID of the A-Arm....and the OD of the crush pins....you can find the size in the Bunting Catalogue......any Bearing supplier can get them and they're very cheap.
Here's an example page of the Oil Impregnated Bronze Flange Bushing
« Reply #4 on: November 18, 2016, 08:09:47 PM »
Wonderful information. Thanks guys
Offline JohnTabata1
« Reply #5 on: November 18, 2016, 08:35:31 PM »
There's more to a bushing. ID,OD x2, shoulder width and OAL
« Reply #6 on: November 18, 2016, 11:05:10 PM »
Quote from: JohnTabata1;70839
Hate to say it but bearings are this way as well.
« Reply #7 on: November 18, 2016, 11:06:32 PM »
Quote from: Langbolt;70837
Oil impregnated bushings never last from personal experience in the working world a solid bushing with grease fittings last longer.
Offline zcarlson12
« Reply #9 on: November 21, 2016, 09:56:45 AM »
Does the Pivot Works kit not work? You would need two kits at $79.99 but it has all the seals, bushings and spherical bearings. Laeger's kit is $250.
The pic on the website is a generic image but I took one of a kit we have here in KY with the three pieces I'm referring to.
https://www.rockymountainatvmc.com/p/760/2052/Pivot-Works-A-Arm-Kit?v=1918
Offline zcarlson12
« Reply #10 on: November 21, 2016, 10:02:57 AM »
I can't the pic to attach of the PW kit. I'll try it again later.
Offline zcarlson12
« Reply #11 on: November 21, 2016, 10:03:45 AM »
I can't get the pic of the Pivot Works kit to attach. I'll try later.
« Reply #12 on: November 21, 2016, 12:11:17 PM »
Quote from: zcarlson12;70876
The pivot works kit you have posted is for OEM arms. All or at least most all aftermarket a-arm makers use a bushing, bearing or heim system thats different than stock.
Offline zcarlson12
« Reply #13 on: November 21, 2016, 01:57:44 PM »
I'm almost 100% sure this is what I used when I put new ones in my Laeger a-arms. I know I didn't get them from Laeger so I'm not sure where else I would have gotten them from. Good luck in your search though.
Offline zcarlson12
« Reply #14 on: December 01, 2016, 10:45:00 AM »
Any new developments?
