Author Topic: 450r to 250r peg adapters  (Read 2280 times)
Offline Cmoss09
« on: April 27, 2019, 10:19:06 AM »
When I ordered my gusset kit from pumashine last year I noticed that he had peg adapters listed, but not in stock. Are there any other places that sell something like this? Thanks
Re: 450r to 250r peg adapters
« Reply #1 on: April 27, 2019, 07:15:40 PM »
Tony is the only person that Iíve seen make them
Offline desertR
« Reply #2 on: April 28, 2019, 01:25:03 AM »
There is nothing that i know of for the'88/89' model years, but the pieces for the '86/87' are easy to fab up. I used 7075 aluminum to make mine and the 450R footpegs cost less then $20.00
desertR
Offline Cmoss09
« Reply #3 on: April 30, 2019, 01:04:49 PM »
Croat1 do you know if he still makes a batch of these occasionally or are they discontinued?
« Reply #4 on: May 01, 2019, 07:37:39 AM »
@Pumashine
« Reply #5 on: May 02, 2019, 05:34:04 PM »
Moved this thread to Pumashine's forum section.
« Reply #6 on: May 04, 2019, 04:20:35 PM »
I cut some adapters for the 86-87 models and have to get them to plating. Also did some ATC adapters. I am currently doing physical therapy to get my right hand to function. Should have adapters ready to ship in a couple weeks. Things are just going a lot slower.
89mm  Mini tooth Shearer in frame pipe chromed! Mounted with Cascade QUIET[/
Offline Burns363R
« Reply #7 on: May 06, 2019, 03:26:24 PM »
so is anyone making 86/87 foot pegs. I need some.  $$$
TRX 370R 86- Stock frame(gusseted)LRD Sub Fram,ISF-No Link Swinger, JD MGC LT Arms) Motowoz Shocks, LED 370/350D pipe, 38 A/S Carb, CR Ignitio
« Reply #8 on: May 06, 2019, 08:53:14 PM »
I have made a few
Offline Burns363R
« Reply #9 on: May 09, 2019, 09:09:40 AM »
Ah im looking for a round tube peg that goes into a nerf that adapts to 86/87
Offline Sand_Blaster
« Reply #10 on: May 09, 2019, 08:47:21 PM »
Kyle it says out of stock but you could give em a email and check. It's where I got mine.
https://www.walshrc.com/product/frame-foot-pegs-mounts/
87 Trx250r & 99 Banshee
Offline Burns363R
« Reply #11 on: May 14, 2019, 09:22:47 AM »
is the 450r bolt pattern the same as the 250r?
« Reply #12 on: May 20, 2019, 04:30:29 PM »
Not even close.
« Reply #13 on: May 20, 2019, 05:06:50 PM »
Peg adapters
Offline Burns363R
« Reply #14 on: May 29, 2019, 11:00:50 AM »
is the 450r frame bolt pattern the same as the 250r frame bolt pattern?  As far as Center to center of the holes?
