Author Topic: kill switch install guide  (Read 538 times)
Offline atvmxr
« on: September 09, 2019, 01:15:39 PM »
Tried searching
have a friend adding a pro armour kill switch so he can race MX.  Do these wire in the same as a pro design?
Can he tie in to the black/white stripe wiring from the stock kill switch?  Tie in to the non grounded coil connection on one side and ground the other wire?
its been so long since I installed a kill switch, i cant remember the wiring.
Online desertR
Re: kill switch install guide
« Reply #1 on: March 26, 2020, 02:12:07 AM »
A little late, but what the heck. The "Pro design" and the "Pro Armor" kill switches are exactly the same inside. They create a connection between the 2 wires when the tether is removed. In this case, the Black/white and Green wires become connected just like the factory run/off/run switch, or the key switch used on some models.
Better late then never
desertR
