If you ever need to FIX a Bent or crushed Foot Peg.....Here's a simple tip!
Take a M8 fully threaded bolt......insert it into the hole in the middle of the peg....or where the bend is.
Install a nut....screw it through the nut.....and then install a 2nd nut......thread it through so the threads come out the other side of the peg.
Now using a wrench.....tighten the first nut against the peg and then the 2nd nut.....using it like a spreader to push out the dent!
VOILA!
LOOKS LIKE NEW!
