Author Topic: Reproduction intake boots  (Read 11800 times)
Offline bushwesl
Re: Reproduction intake boots
« Reply #15 on: June 05, 2022, 09:23:39 AM »
Thanks for checking, Joe. If it struggles to fit the OEM carb, surely it’s only worse on a larger one.
I have an OEM boot that I’m trying to get to fit on a 39 PWK - no luck yet. I’ve done it before with the boiling method, but I just can’t get this one to stretch enough. I’ll keep trying. I was hoping the reproduction boot was going to be a potential option if I can’t get this one to go.
« Reply #16 on: June 05, 2022, 10:43:23 AM »
Wes, have you tried using oil of Wintergreen and alcohol?
« Last Edit: September 11, 2022, 09:20:48 AM by croat1 »
« Reply #17 on: June 05, 2022, 11:22:46 AM »
I've used a heat gun on 3 old stiff oem boots & it worked great
« Reply #18 on: June 05, 2022, 01:06:14 PM »
I boiled the boots in water to soften them and also used a heat gun. I personally like the heat gun best. The boots are hard to hold on to if it is scalding hot all over. The heat gun heats right where you need it.
Offline bushwesl
« Reply #19 on: June 05, 2022, 01:57:18 PM »
Heat gun for the win! Thanks, guys :)
« Reply #20 on: November 05, 2022, 05:36:27 PM »
Areas of concern
« Reply #21 on: February 10, 2023, 06:20:32 PM »
Looks like they now offer a reproduction boot to fit larger carburetors….
« Reply #23 on: February 15, 2023, 10:10:25 AM »
Oversized boot available in blue or red also.
« Reply #24 on: February 15, 2023, 12:01:39 PM »
Has anyone put one of these through a few rides? It would be nice to get a ride report on how they hold up.
Offline All250R
« Reply #25 on: April 10, 2023, 01:21:37 PM »
I worked with the hotfootmoto guy years ago to make the first 86. I never ran the reproduction I got from it, but I remember the material being really stiff. It wasn't a bad attempt, but I never ran it.
I did have an open filter bracket made that is longer on the carb side so that a CR reed boot can be used, which I think is preferable for smaller bore engines instead of the larger volume trx boot. I still have a few. I'd be glad to send a couple.
« Reply #26 on: February 26, 2025, 09:33:56 AM »
@All250R
Jason, by chance do you still have any brackets available?
Thanks
Offline All250R
« Reply #28 on: March 01, 2025, 02:18:51 PM »
@All250R
Thanks
Hey Joe, I have a few left and can send you one. Just the cost of a medium flat rate box is fine.
