Site Sponsors => Pumashine 250R Products => Topic started by: mrtwidster1 on July 31, 2015, 10:44:26 AM
Tony, Can you water jet billet style radiator clamps?
Thanks
Billet hose clamps
AN fittings?
AN fittings?
No , the guy on the other site was or is offering billet hose clamps. Looks like they could be water jetted.
Sorry did not describe in depth . Tim is correct, hose clamps
Sorry, I did not get the hose part. Let me look at the product the guy on the other site is cutting when I get home this evening. . My IP address is blocked here at work. Or could one of you guys copy and paste what the other guy is doing?
Got it, whats the flat spot for?
(http://i61.tinypic.com/2qbxaux.jpg)
The one with flat spot goes on clutch cover for clearance. They come as set and one clamp with flat is included
OK got ya. I don't see a patient anywhere so I guess I can copy them no problem. Heres the one on ebay.
(http://thumbnails114.imagebam.com/42556/8d8d72425551159.jpg) (http://www.imagebam.com/image/8d8d72425551159) $78 for 6 or $14 each
BDT copies everyone else so there is not a problem with me copying them in return.
Or maybe Carlos will send me the DXF file and I will cut for free for .org members only.
When you're done though u need to start hawking it relentlessly on ebay. Include the words pipe, fenders, piston, and oil so it pops up every time lol. I LOVE that!
Sent from my Galaxy S5
I made a program to cut. Looks like a minute each. Cost=$2.50
(http://i61.tinypic.com/17csaa.jpg)
(http://i57.tinypic.com/dvptub.jpg)
Another member is going to send me one so I get a the specifics straight.
That's too cheap lol! Or are you saying $2.50 is what it costs you for 1 min of cut time?
Wow. So guess you could do the one for the Carb also??:jumping0041:
I am not seeing alot of adjustment on these. You would have to know the outside measurement of the manifold boot when carb is in there. Yes its do-able
Right, just cut time. You will see that drilling and tapping the holes will take some time. Then you have material and plating.
OK OK gotcha! That's what I was thinking.
Tony could you build the clamps for our smart carbs? And then for the guys with the Led intakes I cane get you the od and what braid the hose is for the intake.
Nice work Tony. No fog ducking in your shop lol. Sorry to hi jack this thread but any time line for your stealth rad shrouds? Then I will add more goodies to my basket when I will do up an order on your website. Thanks again for your time you spend for us to be able to pimp out our R's
Those look pretty sweet
Id be interested in some blue anodized ones for a 86 ATC 39mm carb boot, hose clamps for coolant and one for the intake side for use with a ESR air box eliminator.
Carlos sent me a clamp to copy, bless his heart. The ring I came up with in my head seems to match the BDT clamp within .005". I will proceed to refine the part and get some of these made up for those of you that do not want to line the pockets of the olds sites 250r salesman.
(http://i62.tinypic.com/30krgjr.jpg)
Haha awesome! So I'm hoping I won't have to have a second mortgage to buy yours unlike btd! Hahaha
these will be cool can't wait to here what the end price will be.
Sign me up for a 38 lol. Carlos is such a nice guy
Yes they are waterjet cut. My sample has terrible edge quality. So the outside has been extremely sanded to give it a machined appearance. :Boobies2: But the inside is a waterjet cut. Don't know who said they were billet but that is:lies: if they are saying it is machined from a solid chunk of aluminum. By definition. A billet is a solid block of aluminum (or any material) with the size depending on the size of your desired part. The larger the desired part, the larger the billet. Contrary to casting, billet parts are created by removing excess material from the billet, essentially the part is carved out of solid aluminum. Both parts above were cut from a sheet of 1/4" aluminum.
I was just referring to the advertised description.
would buy! as well as a intake boot clamp for a 39 :)
bless his heart that was so nice of him to send you one :)
I guess you really can't tell but there is no adjustment on these. If it does not tighten up its useless. I was thinking the little one I made was to large. But the one I got from BDT was .010" bigger. I hope all the inlet and outlet barbs are all the same size. I can see this not working if the barb is too small. I am :thinking: ESR's barbs are on the big side.
in order to make them able to tighten down a little more (be a smidge more adjustable) u could just make the gap between the top two tabs where the bolt goes through a little larger
Typical use of the go to flashy impressionable words billet, oem, like oem, oe, factory, and many more used in misleading ways to get you.
I don't see anywhere on this clamp where it mentions patent or even pending. Sounds like more BS from Carla. Clamps have been shipped. Enjoy knowing you are not lining the clowns pockets.(http://i59.tinypic.com/344cefd.jpg)
Thanks for doing this guys!
Rings are spilling over everywhere
(http://i58.tinypic.com/2yp1839.jpg)
The waterjet cut edge quality is quite ruff. XXX machines the part completely on all outside surfaces,
(http://i60.tinypic.com/14j867t.jpg)
A lil eye candy
(http://i59.tinypic.com/r2kydt.jpg)
Wow, looks great guys!
I kind of doubt he'd get a patent on a clamp. There's about a million different clamps out there. I'm sure this is a variation that already exists, only different part is there custom sized to fit a specific application. Besides, if there patent pending for anodized then these ones can pe patent pending for being powder coated! Ha! Put that in your pipe and smoke it! Bit$%!
Yes, there are plenty for you do it yourselfers.
We checked with USPTO and found nothing. Ebay response was Patent Pending does not have an issued Patent #, not until the patent Issues publicly...Check with USPTO.
Even applications at USPTO have registry #'s. Until we get a # from Believing Delusional Thoughts, production will continue.
yup i specifically asked him for a patent number and he would not give me one! keep making these as long as you can!
ok this is about a 5 min read but confirms exactly what i thought! read it! its short and sweet!
http://www.ericksonlawgroup.com/law/patents/patentfaq/how-to-stop-copiers-during-patent-pending/
Therefore, it would not be appropriate to allow patent applicants to stop others from making, using, selling, and importing the invention (e.g. patent rights) described in their patent application because it is possible the Patent Office might later determine a patent should not be granted.
Further the copier might try to redesign the product/service to avoid the subject matter of the patent application after receiving your notice.
Occasionally a notice letter to the copier will be effective. In other instances you may need to wait until a patent is granted to take action.
^^^^^^^^^^^^^^yup!! you got it! he has no right to tell us we have to stop or he will sue us!! he can politely inform us that he has applied for a patent and give us his application number but thats it!
so what I read he is full of poo. nowhere does it say you can go after the customers.
Correct and we will be handling all questions about these through PM's as he cannot use this against you.
I would not waste my time copying a patent pending article. But since this is all Hype these will soon be available to the public and sold on Ebay with the improved non patented version.
I find it funny cuz all I said was thanks for doing this in this thread not thanks for my clamps!
exactly sam! and as you notice over at the other place he has gone off the rocker! now hes actually bashing people. the most unprofessional act a business owner can do. hes only hurting himself now. i posted a very nice article from a law firm and he now is saying he doesnt care what the article says. i believe this article to be correct to the law so in a sense he is saying he doesnt care about the law. all he needs to do to shut this all down is to give us his patent application number! thats all! and he wont even do that. probably because he doesnt have one.
A real professional businessman who runs a real shop like Arlan or Eddie is far too busy to argue on forums EVERY day or any day for that matter. Simple as that, he's a joke. Never heard of him 10 yrs ago, crawled up out of the sewer like a rat and started claiming 30yrs experience, multiple championships, blah blah.
All I've ever seen was overpriced polished turds for sale on ebay, and buying all the NOS parts he can find then reselling it for 3X the price. "Helping the 250R Community"
i jsut emailed the USPTO for advice on how to get the patent applied for info. if they dont get back to me today ill give them a call in the morning.
Just spotted consulting with his lawyer
[ATTACH=CONFIG]9837[/ATTACH]
This.
Where were all the top engine builders 16 years ago? Oh yeah, building engines. Where was BDT 16 years ago?
Dominating the slot car scene.
[ATTACH=CONFIG]9838[/ATTACH]
I wouldn't know but is that really him.
Oh wow.....time to lay off the foozun ice cream!
Yes thats really him. That picture has been posted in threads a few years back. Pretty funny stuff.
Yeah that's The Best.
Yep, slot car racing at the height of his career. He was banned for cheating!
Haaaaa hahaha!!?!
Is there any links I can read up on that?
There are more pictures of him but I rather not post them. You know I want to "keep it clean" around here. And those are words from the dirt bag himself.
[MENTION=219]Hawaiiysr[/MENTION] http://www.trx250r.net/forum/photo-video/17352-i-finally-got-big-thanks-carlos-bdt.html
This is an excellent read. So damn funny too.
Slot Car Site:
http://www.gofastest.com/ace/
I see his new auctions for the clamps says patent pending.
He needs to after these guys too.
http://www.lamptron.com/2013/01/21/lamptron-liquid-hose-clamps-ii-released/
Sent from my XT1093 using Tapatalk
What about these?
http://www.frozencpu.com/products/15254/ex-tub-1219/Bitspower_Luxury_Reusable_34_OD_Hose_Clamp_-_Blue_BP-SLTC7AL-BL.html?tl=g30c289s723&id=uyS3XCDJ
Slot Car Site:
51 pages! Woa! Hahaha
Pro flow!? Wtf!? Haba
Or Connies cookies lol
http://www.gofastest.com/ace/Cookies.htm
@Hawaiiysr (http://trx250r.org/member.php?u=219) http://www.trx250r.net/forum/photo-video/17352-i-finally-got-big-thanks-carlos-bdt.html
Slot Car Site:
That's hilarious! Wish I had time to read all 52 pages. Look at all the people from that thread that are now banned lol
I noticed the same thing! Haba something like that I'd think would be deleted. With all the crap talk and all the banned members
[/url]
In the end the 5x page thread starter had a lot of trouble with his engine and took it somewhere else to get corrected. His opinion has changed.
They cant afford to delete anymore members,because they have so few left.
Ready to ship
Don't care what the other site does. I have not been contacted about "the Superior Court law Suit coming down on them". When we get the cease and desist call the new design will be switched too.
(http://i61.tinypic.com/52yuep.jpg)
(http://i537.photobucket.com/albums/ff335/dem3500/TRX250R/IMG_20150907_161354142_zpsntcurbpo.jpg)
These were sold way before any of the threats were received on the other site.
Here you go guys!
[ATTACH=CONFIG]9845[/ATTACH]
[ATTACH=CONFIG]9846[/ATTACH]
Here you go guys!
Thast is sweet how the threads are protected on the wire they hang on.
Yea I have a few tricks up my sleeve lol
Yes this is true so the clamping part has been modified as to not copy.
Is he still being a sissy about this. I don't even go on the other board since he threathend me to drag into court if I buy them. And after 3 years ago he saw a picture of me with a trx.org shirt on and within a hour he text me wth. Man that's like fricking middle school.
Sent from my SM-N920R4 using Tapatalk
Fuk that guy and his OEM parts with out the Honda packaging
I would like to place an order for 10,000 radiator clamps please. Please package each one in an OEM ziploc bag
OEM zip lock haha!
I have 9,999 of them finished for you. But I will have to contact Carl to see where to get them OEM zip lock bags.
(https://s-media-cache-ak0.pinimg.com/736x/53/5d/05/535d056f499b77d6df16916f3778a646.jpg)
My wife brings me home garbage bags of the same bubble wrap I've got from bdt from her work that wash machines circuit boards come in from china,Belgium and Mexico. Huh?? Must be a small world.
I'll take a set
I'll take a set
No one is building these cause Carlos threatened to sue everyone on this site who replied to this thread in supreme court. We went on to say the lawyers are going subpoena you in court to go into your private emails and or paypal records to prove you bought his patient pending parts. He is a nasty work of black art. Pretends to be with the 250r brethren.
Just build them. He never is and never was gonna do shit
(http://i1310.photobucket.com/albums/s659/cynnsam/Screenshot_2015-09-05-19-58-03_zpsjfq4roda.png) (http://s1310.photobucket.com/user/cynnsam/media/Screenshot_2015-09-05-19-58-03_zpsjfq4roda.png.html) (http://i1310.photobucket.com/albums/s659/cynnsam/Screenshot_2015-09-05-19-58-09_zpsydi3wqh9.png) (http://s1310.photobucket.com/user/cynnsam/media/Screenshot_2015-09-05-19-58-09_zpsydi3wqh9.png.html) (http://i1310.photobucket.com/albums/s659/cynnsam/Screenshot_2015-09-05-19-58-24_zpsg29usoza.png) (http://s1310.photobucket.com/user/cynnsam/media/Screenshot_2015-09-05-19-58-24_zpsg29usoza.png.html)
Tony,
I will buy 10 of those clamps.
John
Tony,
John
You are funny John, you know this request will make him MADD.
i got the same pm sam got. told me that if i pc'd the clamps then i would be sued too......in pc'd them anyway. never heard from any lawyer.
Where can we see said pending patent?
patents are published online. if it does exist.
He has it on his ebay auctions. If you ask him he tells you to look it up. I could never find it. :Carlos_Kiss:
So it has a patent pending, and threats of legal action are being made, yet nobody has actually provided a #? That's just odd.
The kool-aid is good! Have a sip
So good, you start believing zip lock bags are made by Honda
i asked him for a patent number also and he wouldnt give it to me.
