Workshop => Suspension and Chassis => Topic started by: broken1 on August 27, 2013, 10:59:42 PM
Title: 88-89 spindle?
Post by: broken1 on August 27, 2013, 10:59:42 PM
This new oem rh spindle was given to me & I was told it's for a 250R. I compared it to the one on my 86 & it looks identical except for the integrated steering arm. Could you good folks set me straight on this?
(http://i1080.photobucket.com/albums/j332/scrappyfab/DSCN0680_zps5a5209a5.jpg) (http://s1080.photobucket.com/user/scrappyfab/media/DSCN0680_zps5a5209a5.jpg.html)
(http://i1080.photobucket.com/albums/j332/scrappyfab/DSCN0679_zps89b006b1.jpg) (http://s1080.photobucket.com/user/scrappyfab/media/DSCN0679_zps89b006b1.jpg.html)
Post by: sameltoe on August 27, 2013, 11:03:20 PM
Looks like an 88 spindle, in 88 they changed and went to the integrated arm. And 89 I believe has a tappered spindle.
Post by: red88r on August 27, 2013, 11:47:18 PM
^^^^what Sam said.  Also your 86-87 spindles take the same bearing for inner and outer.  88-89's take a small bearing on the outside and a bigger inner one.  88-89 spindles are the same....it is the hubs that are different with that spacer in there on the 89.  Someone correct me if I'm wrong.
Post by: jamieg45 on August 28, 2013, 06:33:23 AM
That is also a better spindle from the 86-87 ones, way less problems .
Post by: atvmxr on August 28, 2013, 10:08:56 AM
Quote from: red88r;10248
the spindles are not the same.  88 has the step (to act as outer bearing support, no spacer between bearings), 89 has a taper (and requires a spacer between the inner and outer bearing).  They are only interchangeable if you pull one of the bearings out to add or remove the spacer depending on whats going on.
I maybe overstating the obvious,  but to me pulling the bearing out was a big deal so I bought like 3 sets of hubs before I figured this out and got what I needed for my 88.
