Workshop => The Mad Scientist => Topic started by: trx250scar on September 02, 2013, 07:35:32 PM
a while back we had a thread going about making some of these ressi clamps. were did this end up? i currently have removed all the oem mounting brackets off of my 88 oem frame and am in need of this pretty bad
I also may entertain the thought of buying a set of 3. I like to shop with my eyes though.
What frame, the stock frame has clamps. The ones I made were for the front. Ryan should have got them by now. What resi were you using?
I'm in need of a pair too. Fronts, oem frame, tcs shocks. They look just like the rear stock resevoir.
i need one for the rear oem ressi oem chassis as i removed all the oem mounting parts for the rear ressi
Every resi is a different diameter. When some one comes up with a universal design I will make lots. I made 2 sets for Jons PEP rezies. Shipped the same set to rablack21 and they were a 1/4" too big. Had to remake the whole set. So I will need to know the exact diameter of the resi and which frame member you are attaching to.
ok i will get you some numbers. thanks for your attention to this
