General => Projects => Topic started by: troybilt on October 21, 2013, 01:48:57 PM
Title: My Budget Desert/Play Bike build
Post by: troybilt on October 21, 2013, 01:48:57 PM
Starting another 250r build, just for fun.  Its going to be low cost/budget oriented build that is based off of my 89 stock bike.  I got sick of my stock bike and it wasn't selling, so I'm going to do a bolt on build with as much stuff of my own as possible.  I had a few parts left over from the part out of Elsinore so I'm installed those.
So here is where it is today: Stock 89 motor that I plan to run a resleeve stock cylinder 295cc motor setup for XC or torque. Fullbore full fender fronts, ungusseted unmolested frame, Still working on a plan for shocks those will come later.
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/IMG_0565_zpsf07a92dc.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/IMG_0565_zpsf07a92dc.jpg.html)
I reverse engineered some airboxes for White Chassis, which were for Laeger and Walsh hybrids, but I had the original prototype that I welded up and decided to see how it fit in a stock 250r.  Fits like a glove, I used an ESR center mount billet mount to hold it on the front and used an 07 YFZ boot, almost like it was designed for this bike.  Worked out much better than expected.  The airbox fits my YZ hybrid perfectly so I wasn't expecting it to fit the 250r this well.
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/IMG_0564_zps3400d16f.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/IMG_0564_zps3400d16f.jpg.html)
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/IMG_0563_zps8cca329f.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/IMG_0563_zps8cca329f.jpg.html)
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/IMG_0562_zps573d600a.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/IMG_0562_zps573d600a.jpg.html)
As you can see I modified my Elsinore pipe silencer and it fits up nicely.  It has a sweet sound but still rather quiet when its taming 250cc and not 500cc LOL!
Over the weekend, (since this is on a budget) I needed some aarms so I cut up some stock 88/89 aarms and fabbed up some +2.5 wide, +0.5 forward aarms, that turned out pretty good for my first set.  I used the ball joints and the tube ends from the stock aarms then fabbed up the rest.  These use stock length shocks of course.
Well I keep posted stuff as I build it, so far I have 0 Dollars into this except for the bike itself.
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/IMG_0561_zps57a5dd3a.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/IMG_0561_zps57a5dd3a.jpg.html)
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/IMG_0560_zpsce509ee4.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/IMG_0560_zpsce509ee4.jpg.html)
Post by: Pumashine on October 21, 2013, 02:17:20 PM
Did you use a jig to fix the tube ends at the correct distance to fit the frame?
Post by: troybilt on October 21, 2013, 03:06:35 PM
I sure did, I made a fixture from the stock aarms before I cut them.
Post by: jcs003 on October 21, 2013, 03:39:37 PM
looks like a cool build.  cant wait too see more.
Post by: Hawaiiysr on October 21, 2013, 08:04:34 PM
I see your going to do a stock resleeve 295cc. Will this from LED? In his forum he mentioned that he would offer the same build he did for Bill balance for $1000 until February.
Post by: Pumashine on October 21, 2013, 08:34:38 PM
Looks great Troy. Did you make all the bends in-house? I mentioned the jig because welding tends to shrink the over all dimensions.
Post by: rsss396 on October 21, 2013, 08:40:55 PM
Nice! even better Troy has not given up on the 250R I thought maybe we lost him to 4 pokes :)
Post by: fearlessfred on October 21, 2013, 09:58:40 PM
arms look great .we used to do the same thing back in the early 90s before you could just buy long aarms. glad to see you back in action
Post by: atv fan 28 on October 21, 2013, 10:59:00 PM
Troy always has the nicest build threads!!
Post by: jamieg45 on October 21, 2013, 11:06:16 PM
Nice work Troy and the those full fronts look great on there too man.
Post by: etccb on October 22, 2013, 10:12:21 AM
Aarms look great, nice work.
Post by: troybilt on October 22, 2013, 10:22:51 AM
A-arms installed for test fit-up.  They are made from 1" 0.095 Str Tubing.  Not chromoly, cause I didn't have any in my shop.  My other sets will be fabbed/welded by Jerry and use chromoly, these are just for fun.
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/bugetbuild1_zps7305a9d4.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/bugetbuild1_zps7305a9d4.jpg.html)
Here is a picture of my bender: (bent these all myself)
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/bugdetbuild2_zps04a9b746.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/bugdetbuild2_zps04a9b746.jpg.html)
Here is a pic of TIG/MIG combo, GO LINCOLN!!  LOL!
(http://i74.photobucket.com/albums/i260/robltc/Budget%2089%20Build/budgetbuild3_zps967a36b0.jpg) (http://s74.photobucket.com/user/robltc/media/Budget%2089%20Build/budgetbuild3_zps967a36b0.jpg.html)
As far as the cylinder, Dan gave me a 72mm bore OEM re-sleeve cylinder, I just need to hone it a little and find a cool head to match and Wossner or Namura piston kit. I want to run as much compression as possible, 240+ psi.
Fearlessfred, when you going to let me give your desert sled a proper restoration?  LOL!  I thought maybe you guys tried this back in the late 80's-90's.  These turned out better than I expected.  I'm totally happy with the uppers cause I didn't have a 3/4 die for my bender so I had to sleeve 1" over the top to extend them vs. rebuilding the aarms...  but these are just for my play bike so not a huge deal, they work.
Post by: troybilt on October 22, 2013, 10:25:50 AM
I still need to make some longer tie rods, and longer brake lines.  The tie rods are not hooked up right now, they are just zip tied to the uppers.
I will get everything coated once I'm done, next I'm going to attempt a full tubular swingarm.
Post by: jamieg45 on October 22, 2013, 12:03:22 PM
Great work man, so what did you find out about the problem I had bud.
Post by: troybilt on October 22, 2013, 01:39:06 PM
Jamie, they said it was not possible to shift or be off, if the cut file is correct.  I rechecked the cut file, had Jay at FWC check it for me as well and that all appeared right.  I also printed my own set (see on my hybrid thread), I found similar issues with the template:  For instance the graphics hung down about .5 to 1" on the right side kicker area, but I just trimmed that extra material off, the kicker area didn't line up that great, but I played with it for awhile and got looking OK.  I didn't have the same issues as you on the upper right down the nose area, I was able to get that to line up decently.  I could see how one could get off cause its tricky there.  Probably not what you wanted to hear, but that's all I got for you.  thanks for the compliments.
Post by: fearlessfred on October 22, 2013, 07:42:52 PM
Quote from: troybilt;15437
troy If you didn't live 3000 miles away,I would all ready be there with a cooler full of what ever you like to drink.I think you need a little more room in your shop
Post by: jamieg45 on October 22, 2013, 09:29:44 PM
Quote from: troybilt;15480
No problem man, I will save up for another set of grapbics and have you install them for me. Are you and Dan gonna come up to silver lake dunes in July,  if so maybe you can do it then. Hows that sound man.
Post by: troybilt on November 05, 2013, 11:18:22 AM
Been traveling lately and haven't had a chance to work on it, last weekend was my daughter's Bday and we had family here all weekend...  However, the swingarm project is next.  I'm either going to use a used Janssen swingarm I have for a 450r that never sold and shorten it (its a +2) or make a new swingarm altogether from swingarm parts I bought from Jerry that orginally came from Walsh/Six5Design.  I'll probably save that stuff for the production swingarm I'm working on for my own chassis design.
Post by: TRX250R1 on November 05, 2013, 12:16:02 PM
Excuse me if I'm late but did u make that front bumper and if so do you plan on making more?
Post by: troybilt on November 05, 2013, 12:23:02 PM
No that is a hondaline bumper, I made a different one.  This one I repaired and powder coated.
Post by: TRX250R1 on November 06, 2013, 07:49:34 AM
Ok.  That looked a lil different than the Hondaline I saw.
Post by: hontrx265r on November 10, 2013, 10:43:02 PM
Troy, can I get one of those airboxs? Looks familiar, that was a good idea.
http://www.atvriders.com/vbb/showthread.php?482874-airbox-s&highlight=hontrx265r
I would really expect more from you, kinda struck a nerve. I told Jerry he could cut away when I sent him the last flat pattern, as i just don't have time to produce them, and I wouldn't want to take away from the community if someone is in need of a special part. But taking credit for someone elses idea/work when your trying to design parts and open your own company is lame bro...
Post by: troybilt on November 11, 2013, 07:02:24 AM
Hey Mike I reversed engineered them for Jerry... Bro.  I don't sell or have anything to do with them other than that, so you better get your fn story straight bro.  These are reversed engineered for White Chassis.  Mine was the prototype to make sure if fit, this one on this bike is much different, i.e. it doesn't use the Pro Design ring, I welded a ring to it to use a 250r unifilter....  So go f yourself....  I'd expect more from you bro.  I'm done with you, Mike.  You pull this crap without checking the facts, is beyond lame.  How about paying me for those 2 graphics kits I did for you, and you walked out?  You have my number you can call me instead of putting this bs on my thread.  2 faced prick.
Exactly what is says on my facebook page:
"We reversed engineered this airbox for White Chassis. The original design is no longer produced so we were able to reverse engineer the design and improve the fitment. This is the prototype."
Post by: troybilt on November 11, 2013, 07:05:30 AM
BTW, here is what is says on this thread:
I designed some airboxes for White Chassis, which were for Laeger and Walsh hybrids, but I had the original prototype that I welded up and decided to see how it fit in a stock 250r. Fits like a glove, I used an ESR center mount billet mount to hold it on the front and used an 07 YFZ boot, almost like it was designed for this bike. Worked out much better than expected. The airbox fits my YZ hybrid perfectly so I wasn't expecting it to fit the 250r this well.
Doesn't sound like I'm taking credit for the design...  facts, facts.....
Post by: troybilt on November 11, 2013, 07:09:39 AM
And here's what is says on White Chassis's page:
"Airboxes in stock! Thanks to robl engineering for drawing them upand getting them lasered."
Post by: troybilt on November 11, 2013, 07:20:50 AM
Since you are research challenged:
screen shot from White chassis page
(http://i74.photobucket.com/albums/i260/robltc/YZ-Laeger%20Hybrid/Screenshot2013-11-11at61834AM_zps95218cf6.png) (http://s74.photobucket.com/user/robltc/media/YZ-Laeger%20Hybrid/Screenshot2013-11-11at61834AM_zps95218cf6.png.html)
Post by: white chassis on November 11, 2013, 09:16:50 AM
Hey mike there is no need to be bashing on troy. I asked you and you said cool. Neither troy nor did I claim we designed them. He reversed engineered them for me and we are now producing them. I weld them he drew it up.
Jerry
Post by: troybilt on November 11, 2013, 09:19:42 AM
Thanks Jerry!
Post by: hontrx265r on November 11, 2013, 09:42:18 AM
I absolutely said it was ok for jerry to do that. And the way I read "I designed some airboxs for white chassis" sounds like taking credit. "I reverse engineered someone else's" would sounds different. That's great that jerry gave you credit on his page for what job you did. That has nothing to do with research. Im just going to forget about it and call it a misunderstanding as I held you to a higher respect then that but it did read quite differently in my mind. Carry on.
Post by: troybilt on November 11, 2013, 09:53:15 AM
I did not EVER intend to take credit for these airboxes, I did a job for White Chassis, nothing more, my first one was screwed up so I modified it and put it on my 250r.  If you would have called me or emailed me, I would have set the record straight.  You going out of your way to try and degrade my reputation and engineering ability with your post is uncalled for and really had me fuming this morning.
Post by: Pumashine on November 11, 2013, 10:00:37 AM
Quote from: white chassis;17179
Jerry
Troy gave me the same great help building the TRX250R engine stands. Troy can take full credit for these as all I did was modify the drawing as the left and right were not symmetrical. He is a great guy to work with and have nothing but praise for the help he gives to all of us.
Post by: red88r on November 11, 2013, 01:42:47 PM
Guess I missed something.....that being said I am patiently waiting for more updates.:friendly_wink:
Post by: bnau267 on November 11, 2013, 07:36:05 PM
No kidding.  Updates please.  I love seeing actual design and fabrication.
Post by: troybilt on November 11, 2013, 08:03:11 PM
yea I got busy with some other stuff, I haven't had a chance to work on this project.  The part out of my other bike, sort took over my time at the moment... I'll get back on it soon.
Post by: Pumashine on November 12, 2013, 02:28:18 PM
Quote from: troybilt;17219
You can tell Troy is busy. Does not even have time to change his signature. LOL!!!
Post by: troybilt on November 12, 2013, 04:58:58 PM
Yea I need to change that, problem is I've been going thru bikes lately and can't keep up.. LOL!
Post by: troybilt on November 12, 2013, 04:59:35 PM
Besides Elly was my favorite....  :D
Post by: 05450r on November 13, 2013, 12:41:15 AM
Just add "In memory of"..lol
