Classifieds => Wanted => Topic started by: Outlaw525 on October 30, 2013, 07:59:20 PM
Looking for some parts to put a back up engine together
counter balancer with bearing retainer bearing can need replacing I can put a new one on
shifter shaft
shift forks and fork shafts
crank shaft shim/ spacer the one behind the crank shaft gears that the crank shaft seal rides on
this will be to start thanks
I have all that stuff also. Best to get your list finished and get it all at once price/shipping wise.
We'll the other stuff I will be looking for are
clutch cover with water pump shaft
clutch baskit and inner and outer hubs
kick start gear for a 86 or 87
i am not as concerned with this stuff at this time as long as I can get the top and bottom end together and don't have a bunch of money to spend on it yet
as soon as it is to cold to ride it will striped down and redone for next year
I have everything you need.
-Steve
