Classifieds => For Sale => For Sale - Parts => Topic started by: dirtyd on December 01, 2013, 02:09:34 PM
Title: partial trans and misc. engine parts
Post by: dirtyd on December 01, 2013, 02:09:34 PM
All parts came out of an 86 bottom end.
For reference go to fiche http://www.rockymountainatvmc.com/oem-schematic/2
Transmission gears in good shape.  Parts that are missing on the countershaft are
#22 #28 #16 #29. On the mainshaft everything is there, #8 3rd/4th gear is not pictured but is included. This gear does have some pitting on the teeth.
On the gear shift assembly the little collar is missing that the shift shaft connects to. The R shift fork is in spec. The L shift fork (not in first pic) is included and is in spec but has a bur wore into it (see pic). I belive this could be fiiled or ground down. I don't have the center shift fork.
All parts in pic asking $125 shipped. I will separate but would like to sell trans gears together.
shipping to lower 48 states, paypal as a gift or add 3%
Post by: dirtyd on December 01, 2013, 02:10:23 PM
pic of left shift forks bur
Post by: Jerry Hall on December 01, 2013, 05:55:57 PM
Quote from: dirtyd;18852
That shift fork needs to be thrown away.  The tip thickness may be in spec but the fork is burned up and or bent.  A burned shift fork like pictured above is the result of applying constant pressure on the shift lever to hold the transmission in gear and keep it from popping out of gear.  The transmission will pop of of gear when the dogs on the gear are rounded and or the shift fork is bent.
Post by: dirtyd on December 01, 2013, 08:49:14 PM
good to know. thats why I left it out of the first pic, figured I'd throw it in if it could be used.
