Workshop => Engine and Bottom End => Topic started by: taft372 on December 04, 2013, 01:16:15 AM
Title: nitrous
Post by: taft372 on December 04, 2013, 01:16:15 AM
Anyone run nitrous on their 250r? What kit works best, this is a hillshooter that it would be going on with a 370 motor.
Title: nitrous
Post by: Morse250r on December 04, 2013, 05:57:05 AM
Gas or alky? I've always wanted to try but I run alky and not a lot of people I know ran it with alky. A buddy has a kit for an oem cyl and it flies but it's race gas
Title: nitrous
Post by: Pumashine on December 04, 2013, 09:05:16 AM
I have seem guys using it. Last guy looked like he had just seen a ghost. I bet it is super fun but alot of wear and tear on the piston and crank.
Title: nitrous
Post by: SRE on December 04, 2013, 11:16:51 AM
I ran a NOS single cylinder kit on a stock 250r.  It won't hurt anything if you don't get crazy trying to spary to the moon. My kit
had one fogger in the intake with a nitrous and fuel solenoid and a fuel pump.
Title: nitrous
Post by: taft372 on December 04, 2013, 07:42:51 PM
i'm running vp110 fuel
and i was looking at the boss noss kit and i would only do a 10-15hp shot.
Title: nitrous
Post by: SRE on December 04, 2013, 08:36:09 PM
I never tried one of there kits. Seems like the snowmobile guys like them.  I would rather have the fogger in front of the carb.  I think mine was setup for a 9 hp shot. I had a 2lb bottle and it lasted a long time.  You will want some kind of microswitch on the throttle to trigger it automatically at wot.
Title: nitrous
Post by: taft372 on December 04, 2013, 08:54:48 PM
what fogger kits are available. and i dont have a battery and dont really want to install one to run a solenoid.
Title: nitrous
Post by: SRE on December 04, 2013, 09:05:01 PM
Nitrous oxide systems and NX used to make them. I ran a small motorcyle battery. It ran a electric fuel pump and both the soleniods. I don't know how the boss noss kits work.  I always say them installed in the airbox. I assume they are just a dry kit spraying nitrous only and not adding fuel.  Mine was a wet kit so i could control extra fuel and nitrous together.
Title: nitrous
Post by: taft372 on December 04, 2013, 10:09:28 PM
what about jetting? or does the wet kit just blend it so jetting isnt an issue?
Title: nitrous
Post by: SRE on December 05, 2013, 07:21:58 AM
I never changed my jetting. The fogger has a fuel and a nitrous jet in it.  It looks like the boss noss kit is a wet system also. You may want
to give them a call and see what they offer. You may have to retard your timing depending on how much you spray. I never changed mine.
