FAQ's & Technical Articles => Techincal Section => General 2 Stroke => Topic started by: rsss396 on July 08, 2013, 12:31:41 AM
Engine size
http://users.erols.com/srweiss/calcci.htm
http://www.everything2stroke.com/content/36-Engine-Displacement-Calculator
http://www.nightrider.com/biketech/calc_displacement.htm
http://www.mk5cortinaestate.co.uk/calculator2.php
compression ratio
http://www.torqsoft.net/compression-ratio.html
http://users.erols.com/srweiss/calccr.htm
Squish Velocity
http://www.torqsoft.net/squish-velocity.html
piston position / crank angle
http://www.torqsoft.net/piston-position.html
Piston speed
http://www.csgnetwork.com/pistonspeedcalc.html
calculate speed
http://users.erols.com/srweiss/calcmph.htm
engine building formulas
http://www.macdizzy.com/formulas.htm
Port Timing Calculator
http://www.modelenginenews.org/design/tcalc/TCalcForm.php
help with using the port timing calculator
http://www.arboristsite.com/chainsaw/85786.htm
http://lambretta-images.com/archive/porttiming.php
2-STROKE_TUNING_PORTING_DESIGN Program
http://www.330.dk/
Tube notcher calculator
http://cobratorch.net/ttn_dxf/
Engineering Calculators - lots of them
http://www.calculatoredge.com/english.htm
Tube Size vs. Strength
http://www.rorty-design.com/content/tube_size_vs._strength.htm
gearcommander. doesnt have 250r specific but just choose 450r then input your gears and and tire size etc. or input it all manual http://gearingcommander.com/
Octane Calculator
for mixing differant octane fuels
http://www.bazellracefuels.com/Calcs/OC1.htm
http://www.wallaceracing.com/octane-mix-calc.php
Convert HP-TQ-RPM Calculator
if you 2 of the 3 inputs you can fiquire the 3rd http://www.wallaceracing.com/HP-TQ-RPM%20Calc.php
Calculate Inertia force of piston
see the effect of what a different rod length will have on the rotating inertia http://www.wallaceracing.com/Calculate-Inertia-Force-of-Piston.php
Here's a link to my Port timing calculator I wrote using the Formulas from Gordon Jennings Book.
http://www.two-stroke-addicts.freeserve.co.uk/downloads.htm
Or would it be better for me to attach the ZIP ? (Can't......it's 1.45MB)
Just let me know so we can keep these pages clean
You ROCK rsss396 for adding all this great info!!!!
Thanks Langbolt!
hey guys there is some nice calculators on Langbolts link follow it and download them
Optimum Intake Runner Calculation By Bowling
http://www.bgsoflex.com/intakeln.html
