Workshop => Engine and Bottom End => Topic started by: tingley596 on February 08, 2014, 12:21:58 AM
Title: New Esr Pv cylinders
Post by: tingley596 on February 08, 2014, 12:21:58 AM
What's the word on these? Just bought my old r back for $500 and she needs a new cylinder.
Post by: rk88r on February 08, 2014, 01:09:06 AM
Probably the best option short of a sphinx.
Post by: tingley596 on February 08, 2014, 02:33:36 AM
How long have these new ones been out? I sold my r this time last year and it was a different cylinder back then. Is anyone running these yet? Any dyno runs? How do they run with there clean up trx9 and not there full port job
Post by: tingley596 on February 08, 2014, 02:38:01 AM
Is anyone running them? This new style wasn't out when I sold my r this time last year. How do they compare to there old cylinder and Pv setup?
Post by: tingley596 on February 08, 2014, 02:38:55 AM
How do they compare to there old cylinder and Pv setup? I sold my r this time last year and these weren't out yet.
Post by: ledperformance on February 08, 2014, 12:39:03 PM
The ESR power valve gate valve is wider than the gate valve in the Pro-X or Sphinx cylinders. That is a big improvement. A narrow gate valve compromises the shape of the roof of the exhaust port. I would be nice if even the ESR gate valve was even wider on the 78mm bore cylinders. Ideally the valve would be the full width of the exhaust port and come as close to the ring as possible with out touching.
Post by: Hawaiiysr on February 08, 2014, 09:28:49 PM
They have new PV cylinders? Other then what they use to carry? Got a link?
Post by: tingley596 on February 09, 2014, 03:42:41 AM
http://www.eddie-sanders-racing.com/product_p/310-cyl-npv.htm
You can tell they are completely different from the ones that where out this time last year and prior. The Pv use to stick up like the one on the main page. Cylinder casting also looks different too.
Post by: jcs003 on February 09, 2014, 04:42:51 AM
here is the PV cylinder:
http://www.eddie-sanders-racing.com/product_p/310%20power%20valve%20cylinder.htm
Post by: trx250scar on February 09, 2014, 08:44:46 AM
Quote from: tingley596;25156
I am confused. The cylinders pictured on the website look no different other than the Yamaha powervalve cylinder. ESR seems to be manufacturing all cylinders to accept a powervalve, just using a plug in place of the pv.
Post by: tingley596 on February 09, 2014, 11:31:55 AM
Nm I see what's going on here. Thanks guys
Post by: etccb on February 09, 2014, 12:52:49 PM
Same cyl that they have always had. Can get non pv, pv ready and pv. Some tooling changes were made within the last year that cut out the water jacket and the base nut seat.
