Classifieds => For Sale => For Sale - Parts => Topic started by: johnny22 on March 07, 2014, 12:14:21 AM
Title: slingshot clutch
Post by: johnny22 on March 07, 2014, 12:14:21 AM
(http://forums.trx250r.org/vbulletin_imports/15_1133_2017-04-18_5947.jpg) slingshot clutch for sale. I just bought it from a member on here and now I need money. Its missing one bolt that's how I got it. No balls are missing they are all there I'd like to get what I paid. I think it was 220 shipped so let me know 8316827219 call or text thanks
Post by: Pumashine on March 07, 2014, 09:32:20 AM
I will take it for sure. PM sent
Post by: atvmxr on March 07, 2014, 10:26:52 AM
where can I find more information on slingshot clutches?  I dont understand what they are for or why I would need one...
Post by: havinnoj on March 07, 2014, 10:32:11 AM
Quote from: atvmxr;28101
Gigot Performance - Slingshot Lockup Clutch 250r (http://www.gigotracing.com/index.php?option=com_content&view=article&id=48&Itemid=53)
Post by: Pumashine on March 07, 2014, 10:37:59 AM
Quote from: havinnoj;28102
I buy these whenever they pop up. Dealer cost is over $300.  I have never experienced a lag between the transition from fiber to lockout grip.
Post by: rablack21 on March 07, 2014, 10:50:41 AM
Are these just for drag racing or are these like the rekluse clutches?
Post by: Pumashine on March 07, 2014, 10:57:41 AM
Quote from: rablack21;28105
These are for motors with over 50-60 HP. A clutch will only last 1 season on a Puma. They keep the clutch from loosing engagement or clutch slip as most put it. So your looking at any time you get to 1/2- 3/4 throttle for hook up.
Post by: rsss396 on March 07, 2014, 10:59:52 AM
not like a reklus, they do not disengage the clutch they only ad clamping power, but you must remove 1fiber and 1 plate to allow for it to fit under the side cover. Tony can better explain mods needed since I have only ran it on a cr500
Post by: Rupp250 on March 07, 2014, 11:35:39 AM
If Tony falls through I'll pick it up Johnny.
You guys shouldn't have left Bako.
Post by: Pumashine on March 07, 2014, 11:42:12 AM
Quote from: rsss396;28107
Yes, remove 1 fiber and 1 plate. You must have the 89 clutch update with it. Sometimes the seller sends it along but not with new. Usually a .010" shim comes with it for the washer at the end of the push rod bearing bearing. It it is recommended to use the heavy duty barnet clutch springs. Oh wait, that could just be my recommendation. It comes with the 5 allen head bolts. I always replace them with the stainless version. You want to assemble off the bike as you need to keep all the ball bearings in place. *Hint is to tighten the bolts up evenly. Some guys just want to use 2 bolts with an impact wrench. then tighten the other 3 freely. Very dangers as you can strip the inner hub and ruin the part it just cost you $100 to have modified.
Post by: Pumashine on March 07, 2014, 11:43:19 AM
Quote from: Rupp250;28112
Sorry  Rupp250, he's already shipped it!
Post by: atvmxr on March 07, 2014, 11:51:27 AM
uhhhhhhhhhh  did you go to that website??  there is like 2 sentences there that provide no information and thus why I posted my question...  :black_eyed:
:smile-new:
so i dont get it.  the clutch is slipping so you remove clutches???  seems counter-intuitive to me!!  why not use the 9pack hinson clutch?  guess it doesnt work, or else you would be using it.   this must be an issue for 250r and banshees, as I dont have any issues with my built zilla motors slipping the clutch or only lasting a season of riding. they just snap the fingers off the basket instead :culpability:
Post by: johnny22 on March 07, 2014, 12:04:15 PM
sold it to tony Russell sorry.  We didn't want to but we had a 3 hour drive and didn't want to get home super late. basically my mom was ready to go. she decides how long we stay haha
Post by: havinnoj on March 07, 2014, 12:05:27 PM
Quote from: atvmxr;28117
:smile-new:
The manufacturer is usually best suited to answer any and all questions you have. :friendly_wink:
You remove a clutch plate so this can fit inside the cover.  Lockups apply more pressure to the pressure plate as RPM increases.  The more pressure on the pressure plate, the less the clutch slips.
Post by: Pumashine on March 07, 2014, 12:05:49 PM
Yes, bigger motors have larger diameter clutch plates and have more gripping strength. The 250r was only engineered for 40HP. When yo double that the clutch slips. You don't use all the friction plates when riding. Only the outside ones are working and when under load the inner ones start holding. So when your just riding around you don't need all the friction disks. Then when under load the lockout takes over. I am guessing you just don't understand how the clutch operates!
Post by: atvmxr on March 07, 2014, 12:13:20 PM
Quote from: Pumashine;28121
well I thought I did, but seems I done went and learnt more info now    :onthego:
thanks OJ and Puma
Post by: Pumashine on March 07, 2014, 02:23:45 PM
Quote from: atvmxr;28122
thanks OJ and Puma
Its taken a few years of learning. When you go to replace a clutch the fibers on the outside are completely gone. The ones in the middle are still have lots a life one them. So if you get in a pinch you can always grab an old disk out of the middle and use it.
Post by: JesseA420 on March 07, 2014, 03:53:20 PM
it uses the centripical force, the greater the rpms, the more centriphical force there is. the bearings you see sit on a angled "ramp" towards the outside of the clutch. as rpms increase, so does centripical force, therefore throwing the bearings out farther harder, therefore pushing in on the clutch plates harder, and allowing the clutch to hold more horsepower. i have ran one on my built raptor for several years. works well, and a cost effective alternative to the pricey direct drive units.
