Workshop => Suspension and Chassis => Topic started by: mrmoto on July 09, 2013, 01:34:36 PM
Title: Paddle Tire Recommendation
Post by: mrmoto on July 09, 2013, 01:34:36 PM
I have an '85 ATC and currently do not have paddles for it nor have I ever owned them so I am not sure what to get. I haven't ridden my ATC in the sand since the late 80's but I do remember running a set of 350x stock rears that ran much better then stock. I have never run anything but stock on the front so I really have no experience at all with paddles.
I want to be able to fly around Glamis and Pismo but also to some fun drags up competition hill as well
I have an extra stock front wheel 23.5 x 8 x 11 and 2 extra sets of stock OEM TRX rears 20 x 11 x 9 wheels that I can install new tires on or buy complete wheels if these rims are not the best size to run paddles on.
I am running the stock swingarm and as for HP I am not sure but this is not a BB rocket. 1 step up from stock? Maybe 40 HP??? Here are the engine specs
Original OEM cylinder
Bore - 66.5
Stroke - Stock
Porting - CT Racing mx port (this may change)
Piston - Pro-X cast piston
Compression - 190 psi
Head - Stock
Pipe - PT Hi Rev Fatboy 2 silencer
Reeds - v-Force 3
Carb - 38 AS
Ignition - '01 CR250
Fuel - 100 oct Unocal 76 pump
Post by: Morse250r on July 09, 2013, 02:15:58 PM
I'd say a 21" 7/8 paddle hauler or extreame. But I've never run Cali sand before   My stock cyl I'm running 21" 7 extreames and I can't hold it down
Post by: nico on July 09, 2013, 02:21:41 PM
For the front, there aren't many choices... We run a stock size Skat Trak Mohawk on a factory wheel (minus the gold), purchased from Recreation Tire.  On the back, I'm not sure about Pismo or Glamis sand, but for where I'm at, it's hard to go wrong with a 20" Skat Trak Hauler, with eight paddles.  I personally like the 21x12-8's better with 8-9 paddles better, but they make our trike feel kinda tippy.
Post by: mrmoto on July 09, 2013, 04:38:55 PM
Are tires like these ok or should I stick to known-good brands like Skat-Trak?  http://www.ebay.com/itm/261242970234?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Post by: PROX370R on July 09, 2013, 05:20:07 PM
Quote from: mrmoto;2174
mrmoto, I had a set of those paddles.. they came with my R when I bought it.. they worked really well.. the only problem I had was that they leaked air in the center of the tire where the tread is... but that's only because the tires were really old and worn out... not sure how long the previous owner had them.. but I guess the sand finally took a toll on them..  good luck man hope this helped... -simon
Post by: nico on July 09, 2013, 05:22:52 PM
I actually have a set of those, that I bought for cheap.... I think I offered him $140 and he took it.  Cost vs. performance, I've been pretty happy with them, and keep them for loaners and on my cruiser when it's not wearing Sand Skate II's.
The quality seems hit or miss (what I've read on other forums), but mine have been plenty good for the cost.  They don't get the traction of the original Skat Trak Haulers, but if you haven't been to the dunes alot, and don't really plan on going back too often, they will work fine.  They are a little too much paddle for my stock TRX250R with a FMF pipe, but might be just about right for an ATC's lighter weight.
I'd look around for some used Haulers... Lots of people are coming off their dune season as the temps get warmer.  Usually some good deals floating around on Craigslist and forums.
Post by: Rupp250 on July 09, 2013, 05:25:27 PM
For your set-up, yes they will be fine. That shop is located out here in Sacramento. The shop had a large run of tires made, they are scuffed carcasses with paddles molded on. Just like Skats. For you setup power wise I would run a 20" 7-8 paddle.
I actually have a 20X10X10 8pdl hauler I switch to every once in awhile on my bike, just depends on what I feel like. This is with 70hp.
Post by: mrmoto on July 09, 2013, 06:55:22 PM
The ATV Gods are smiling at me and this site. I just got the following email from RMATV. I also have a 10% code for them.
You now have $100.00 in Cash Rewards in your account, ready to spend!
So I could get a set of these for around $145.00 out of pocket and mount them to a set of my OEM rims but is 20x11-9 (8 paddle) going to be too much for my motor? that's the only tire that will fit the rims I have
http://www.rockymountainatvmc.com/p/43/81/165/1112/-/6053/Skat~Trak-Hauler-ATV-Tire
Post by: mrmoto on July 09, 2013, 06:58:00 PM
Quote from: nico;2182
Wow that is really nice of you. Thank you very much!!! :)
Post by: derby on July 09, 2013, 07:48:35 PM
I bought 2 sets of the skat trak knock offs.  One set was fine but the paddles wore down quick and cracked when I ran my usual sand/trails.  This also includes asphalt parking lots at the dunes.  The other set cam with a hole in the side wall.  I was able to plug it but still for a brand new set?  My second set it seems the paddles are holding up a little better.  As far as sizing they are narrower than the skat track and slightly taller.  Just a heads up I would probably buy another set if I needed it.
Post by: mrmoto on July 09, 2013, 11:17:18 PM
Are TRX250r/400ex OEM rims really heavy? The set I moved around today seem heavy to me. Could just be the tires though.
I have $100.00 in rewards and a 10% code to use at RMATV. Should I buy the Skat Trak Haulers 20x11-9 (8 Paddle) tire and mount them on OEM  20x11-9 rims?
Or should I get all new wheels that are 20X10-10 (7-8 Paddle)?
Post by: grinNbarritt on July 10, 2013, 01:29:18 AM
I tried a friends set of haulers on my 85 ATC once.... fine if you just wanna go staight.... My 86 ATC came with a set of sand skates, I liked those alot better.  JMO    Jim
Post by: atv fan 28 on July 10, 2013, 01:41:37 AM
for all around riding 20/10/10 is my favorite. I will run straight paddles over V paddles every day of the week. JMO
Post by: mrmoto on July 10, 2013, 02:54:18 AM
Just found out I can get a set of haulers free. I believe they are 20x12-8 (7 Paddle) The rims look cheap or maybe Dougles/ITP and look old but I am told the tires have no plugs and they hold air.
I definitely want to do more then just go straight so probably I will start with the free Haulers and buy a set of the Edge type tires and have both.
Post by: nico on July 10, 2013, 09:48:23 AM
Anything free is the way to go...  Seven paddles will do well, and let the engine rev a little easier than eights (higher top speed also).  I have at least 8 pairs of sand tires I swap around and try on different machines, and let friends do the same.  Each engine combo has a size and number of paddles it likes the best, for the conditions.  Every now and then, I still throw on some old 20x10x10 Sand Skate II's and go on 60 hp "drifts" through the dunes.  lol.
Post by: motofool250r on July 10, 2013, 11:30:55 AM
i ride everything with straight paddles just shift your butt off the seat to the high side when your side hilling and there is no problem.
Post by: mrmoto on July 11, 2013, 12:23:19 PM
I now have the freebie paddles in my possession. I filled them to 10 lbs psi yesterday to see how well they hold. I do see some very slight weather checking though so I probably won't run then, at least not more then a test run.
I am going to order some Skat Trak Hualers. Trying to decide between the standard Haulers and the Extreme Haulers?
Also, I bought a seemingly nice set of Sand Skate ll's off ebay to give a try. I have read they are heavy so I may look at some Skat Trak Edges as well.
Post by: atv fan 28 on July 11, 2013, 12:34:43 PM
with your setup i would just run the Haulers instead of the Extremes. Both tires have the same paddle height, the Extremes are just thicker at the base.
Post by: Rupp250 on July 11, 2013, 12:36:24 PM
One of my set of haulers are a little weather checked as well. I put some sta flo liquid starch in them and they are holding just fine.
Post by: nico on July 11, 2013, 01:01:53 PM
I've always been told that the Extremes were better if you were planning on running across any hard pack or asphalt (like in Oklahoma), but to drop the paddle count by one.  For example, and 8 paddle Hauler would be closely equivalent to a 7 paddle Extreme.  My brother ran 20x10-10 8-paddle Extremes on his 85 ATC for years and loved them, but they are a bit much paddle for my stock-engine TRX if the sand gets damp.  I know the Extreme paddles are far less prone to rolling over.
Post by: motofool250r on July 11, 2013, 04:18:22 PM
paddles always leak i have some severely weather checked knock offs and they have ran just fine.
Post by: mrmoto on July 11, 2013, 05:40:46 PM
Thanks for all the great info everyone! I will start with what I have so far before I make any more purchases. Eventually I am going to want better rims for at least one of the sets I just got so I can address it all again later.
I am hoping to get to the sand very soon and rip it up! I am very anxious and excited to get it out there again. I haven't had it in the sand since the late '80's :encouragement:
