Classifieds => For Sale => For Sale - Complete Bikes => Topic started by: CustomSeatsOfLouisiana on March 15, 2014, 08:06:39 PM
Selling my 496 Sabertooth Hybrid..
price complete $8,000
chasis without motor $4500
Chasis includes($4500);
-Modified and lightened 450R chasis.. chasis accepts 250r and/or 450r motors without any modifications.
(chromoly engine cradle was fabricated to accept both motors). Rear of the chasis was notched for carb and intake clearance.
- Swingarm = +14 double arched aero tube in chrome
- Subframe = one off double arched aero tube to match subframe. Mounting points are raised similar to yfz for a clean look.
- A Arms = Single A arm setup with +4 -2 measurements
- Tie rods = aluminum tie rods
- Suspension= Chromoly front struts, marvin shaw rear
- Axle= JJ&A aluminum drag axle
-Brakes = Brembo caliper and alum stay. setup was the first sold for a 450r from Cuervo Racing.. Master cylinder is off Honda CRF to eliminate resi
- Controls = ASV clutch lever, Moose polished throttle.
-Stem= chromoly lightweight stem
-Wheels= Direct Drive custom cut 12x3" spindle mounts.
-Pegs= aluminum footpegs
-Grips= RIS billet alum grips
-Body= scooped hood with one off candy paint with 2 stage hydro dip
-Carrier= polished 450r with ceramic bearings
-Fuel cap= polished alum cap
-Seat= shaved height with carbon fiber material.
-Radiator= Aluminum light weight radiator
-Chain= Gold D.I.D chain
-Sprockets= 15, 16, 17 fronts 36, 34, 32rears
-Bolts= Titanium pivot bolt, Titanium brake bolts, Allen head polished chasis bolts
Engine Specs;
496cc Sabertooth package
52mm Lectron w dual power jets and fuel pump
Nate McCoy billet tranny with 1-5 override/ neutral down
Direct Drive lock out with extended shaft
MSD programable ignition,MSD Coil, Ballistic 4 cell battery
Shearer oof drag pipe with interchangable stinger/silencer
pingel petcock
custom alum intake
Spare Parts;
-OEM complete transmission with all forks and components.(not override)
-CR Ignition and timing plate from ESR
-2 oem rev boxes for trx250r
-2 oem coils for trx250r
-spare set of oem plastics (450r)
-spare fuel pump
**Chasis is 100% new and has never been raced since fabrication.Color is a custom Illusion Red powdercoat. All other components are polished or chromed**
(http://forums.trx250r.org/vbulletin_imports/32_1287_2017-04-18_4458.jpg)(http://forums.trx250r.org/vbulletin_imports/32_1286_2017-04-18_926.jpg)
That is a crazy, awesome quad. Not my style but very nice.
Dam what a rocket lol nice machine what top speed on that
not sure of a top speed.. i had the pipe chromed yesterday and sent the carb off for polish. i also had a custom 32 tooth ti rear sprocket made and purchased a new nitrous kit..once the carb gets back we will hook up the new components, dyno tune it, and ill be able to give you some times in the 1/8 mile asphalt as well as 300ft dirt.She should fly though.
updated pics.. and price drop. $7500 bike with all spare parts
$5800 motor/pipe/carb with CR and MSD ignitions and Boss Noss nitrous kit
$3500 complete chasis minus motor(http://forums.trx250r.org/vbulletin_imports/32_2435_2017-04-18_7333.jpg)(http://forums.trx250r.org/vbulletin_imports/32_2436_2017-04-18_1244.jpg)(http://forums.trx250r.org/vbulletin_imports/32_2437_2017-04-18_1233.jpg)(http://forums.trx250r.org/vbulletin_imports/32_2438_2017-04-18_1364.jpg)(http://forums.trx250r.org/vbulletin_imports/32_2439_2017-04-18_705.png)
