Workshop => Suspension and Chassis => Topic started by: Kevhes11 on March 16, 2014, 02:13:02 PM
I have an 86 frame that is a roller. Ive got the complete a arms, spindles hubs ect 86 style. I just picked up Walsh +2 a arms. I think ive read that the walsh a arms need to use the 88-89 style hubs spindles and what not.. is that true? if so, is it best to invest in a 400ex set up?
If they are designed for R spindles 86 will work fine. 88-89 are a little nicer though.
That's good news I thought I was going to have to buy 88-89 style
You may want to confirm that they are for R spindles. 10 years ago a lot of a arm makers favored ex spindles.
Good point. I don't know how to confirm though. I got them used
I think the only difference is the spindles 89 are tapered and I think 86-88 are not tapered
(http://forums.trx250r.org/vbulletin_imports/178_1293_2017-04-18_6035.jpg)
(http://forums.trx250r.org/vbulletin_imports/178_1294_2017-04-18_736.jpg)
Measure the stock arms and find the difference between upper and lower. Then do the same with your Walsh's. Ex style arms have a relatively shorter upper.
I had stocks before now I got +2
Spirit aces is correct. 400ex hubs will fit on a 1989 spindle in stock form. If you remove the tapered collar from them, supposedly they will fit an 88 spindle.
Does anybody have the complete front end pieces for sale? Hubs spindles ect
