Workshop => Suspension and Chassis => Topic started by: hickwheeler on March 24, 2014, 05:27:49 PM
I have older jd arms. Witch use the 14mm balljoint. What do you guys think about modifying to use the ricky stator joints.
Is there enough "meat" there to drill out? Have you been bending the 14mm ball joints?
14mm is probably fine. I just broke both on left side in crash. just wondering about strengthening it up a bit. or am I just over thinking it
I wouldn't drill them out. Maybe the bottom could handle it but def not the top or you'll be replacing the a-arm after the next crash.
thanks that's what I needed to know
