FAQ's & Technical Articles => Techincal Section => General 2 Stroke => Topic started by: rsss396 on July 09, 2013, 10:12:25 PM
Title: piston failure chart
Post by: rsss396 on July 09, 2013, 10:12:25 PM
[ATTACH=CONFIG]267[/ATTACH](http://i870.photobucket.com/albums/ab265/rsss396/250r%20site/page-0_zps23e07e48.jpg)
Post by: rsss396 on July 09, 2013, 10:56:58 PM
well not really I can't get the picture large enough to read the small print :(
it is a PDF file that I converted but it killed the quality how do I attach PDF's
Post by: rsss396 on July 09, 2013, 11:18:55 PM
yes Dan the large image is photobucket and the small is attached, I can go as high as 400% on IE and its readable but not as nice as the PDF
Post by: atvmxr on July 10, 2013, 12:34:30 PM
awesome!
that next to last one should read big end rod bearing let go (it does vaguely hint at a lower end problem) ....  I've had that bite me a couple times not realizing that was the issue only to destroy a new piston in a few minutes....
Post by: trx250r88 on July 10, 2013, 10:44:35 PM
Quote from: atvmxr;2505
awesome!
i had that happen last year too.the piston looked just like pic.rod bearing went,piston detnating on the edge.the motor still ran with major knocking noice.
