General => Lounge => Topic started by: ikas on April 24, 2014, 10:49:03 AM
Title: Laeger protrax spindle intrest?
Post by: ikas on April 24, 2014, 10:49:03 AM
Hello, i'm "new" on this forum been on it looking since september 2013 and before that on .net
I have the opportunity to get a hold of machining new spindles that is a replica of the Laeger protrax spindle. The spindle will most likely use 7150 aluminium and be machined in a OKUMA multus B300-W.
I live in Sweden and there is a local business that I have been in contact with about doing a run.
If there is interest there is a big opportunity that there will be a run.
I have sent them measurements and will get a price for what I could expect it to cost to produce the spindles. The price I will get is for 1,5,10,15, and 20 pairs.
Post by: Hawaiiysr on April 24, 2014, 11:51:00 AM
Me:)
Post by: havinnoj on April 24, 2014, 12:42:57 PM
I'm interested.. but would need more details before I commit.
Post by: 89Longrod on April 24, 2014, 12:55:07 PM
I would also be interested in having a spare set of spindles but I will wait on some more info.
Post by: ryanowarrior on April 24, 2014, 09:32:00 PM
Quote from: 89Longrod;32303
Same here
Post by: rk88r on April 24, 2014, 11:02:16 PM
Interested
Post by: ikas on April 25, 2014, 02:57:21 PM
Happy to see theres interest! I will post some info as soon as I hear something from the supplier.
Post by: bnau267 on April 25, 2014, 09:35:25 PM
Quote from: ikas;32389
Are you doing the 450 brakes or the 250r.  I'd buy if you go down the 450 path.
Post by: croat1 on April 26, 2014, 06:43:51 AM
Quote from: bnau267;32420
Are you doing the 450 brakes or the 250r.  I'd be interested if you go down the 450 path.
I am also  interested if they use 450 brakes
Post by: troybilt on April 26, 2014, 09:09:25 AM
Count me in as well, I'd might be interested in large quantities myself.
Post by: rk88r on April 26, 2014, 09:10:03 AM
Great idea on using 450 brakes.
Post by: bnau267 on April 26, 2014, 10:48:09 AM
Quote from: rk88r;32454
Plus you can use the front spindle shafts from Lonestar.
Post by: Tbone07 on April 26, 2014, 12:45:49 PM
So i'm guessing Laeger is unwilling or unable to make these anymore? Or are you able to make them at a lower cost than Laeger?
Post by: havinnoj on April 26, 2014, 01:04:41 PM
Quote from: Tbone07;32466
Last time I checked with Scott, maybe 6 months ago, they were still making these.
Post by: croat1 on April 26, 2014, 03:35:05 PM
I'm assuming ikas can make these cheaper.  this is a Laeger Protrax component price sheet from maybe 3 years ago (prices might be higher now???):
per Laeger: It is a lot cheaper to purchase a complete spindle ($850) instead of the individual parts, but here you go:
Item        Qty Per Spindle   Price   Total Unit Cost
Aluminum Body                                                            1     $425.00   $425.00
T-Pin        1   $200.00   $200.00
Thrust bearing                                                            1   $51.96   $51.96
Lower Bearing                                                            1   $16.13   $16.13
Bearing Collar                                                            1   $7.53            $7.53
Spindle Shaft                                                            1   $100.00   $100.00
Shaft Collar                                                            1   $27.50   $27.50
Dust Seal        1   $4.18    $4.18
Back Plug        1   $5.25    $5.25
LG Zerk Fitting                                                            1   $1.66            $1.66
Mono Ball Kit (Lower)                                                    1   $35.00   $35.00
Mono Ball Kit (Upper)                                                    1   $35.00   $35.00
Snap Ring        2   $1.25    $2.50
SM Zerk        2   $0.98    $1.96
Set Pin        1   $0.5 0   $0.50
Lug Assembly                                                            1        ?               ?         not sure what is considered the lug assembly
Lug Body        1   $100.00   $100.00
Brass Bushings                                                            2   $12.00   $24.00
SM Clevis        1   $100.00   $100.00
Lock Nut        1   $1.75    $1.75
SM Zerk        1   $0.50           $0.50
1/4 x 28 Lug Bolt                                                    2   $1.75    $3.50
1/4" Washers                                                            4   $0.50    $2.00
1/4" Lock Nuts                                                            2   $1.25    $2.50
7/16" Bolt        2   $25.00   $50.00
7/16" Nut        2   $1.50    $3.00
5/8" Bolt        2   $2.50    $5.00
5/8" Nut        2   $1.75           $3.50
total per spindle: $1,209.92 if purchased by individual parts
Post by: croat1 on April 26, 2014, 03:39:36 PM
well that didn't post too well....
Post by: croat1 on July 25, 2014, 11:34:28 AM
any updates?
Post by: sameltoe on July 25, 2014, 01:18:37 PM
Way to scare him off Joe! lol
Post by: croat1 on July 25, 2014, 01:31:09 PM
Quote from: sameltoe;39829
I figured I would check if he had any updates before I purchase new from Laeger.
Post by: pinned250r on July 25, 2014, 02:55:11 PM
[MENTION=142]dirtyd[/MENTION] may be in need of one kf these!
Post by: dirtyd on July 25, 2014, 09:26:10 PM
Quote from: pinned250r;39842
why do I need one of these? to rich for my blood
Post by: pinned250r on July 26, 2014, 09:20:15 AM
Quote from: dirtyd;39859
I'm sorry man, I meant [MENTION=89]supernutt[/MENTION]
Post by: supernutt on July 26, 2014, 10:05:03 AM
I just need the upper stud or clevis that goes through the upper control arm
Post by: rk88r on July 26, 2014, 01:26:21 PM
A 14mm or 16 mm? The 14's are discontinued.
Post by: supernutt on July 26, 2014, 04:32:30 PM
14mm of course.......
