General => Lounge => Topic started by: Nickthompson on June 02, 2014, 12:48:59 AM
Title: Question I need answered
Post by: Nickthompson on June 02, 2014, 12:48:59 AM
Can I run an oem cylinder that was ran on a long rod crank with spacer plate on a short rod crank by not using spacer plate? If so what style/year piston do I need to get to make it work? Need some info back on this guys!!
Post by: Jerry Hall on June 02, 2014, 01:01:59 AM
No spacer plate needed if you run a long rod crank with a 1987 to 1989 piston
No spacer plate needed if you run a short rod crank with a 1985 to 1986 piston
Spacer plate needed if you run a long rod crank with a 1985 to 1986 piston.
Post by: Nickthompson on June 02, 2014, 01:06:21 AM
Thanks for the info!
Post by: Pumashine on June 02, 2014, 09:52:33 AM
Quote from: Jerry Hall;35568
Seems this should be a sticky in the tech section with the difference between the two explain.
Post by: Nickthompson on June 02, 2014, 12:46:37 PM
I would love to hear an explanation between the two!but for now I have the info I need!
Post by: Langbolt on June 03, 2014, 07:46:14 PM
Hey Nick, Few more questions:
Do you know the STROKE of the Long Rod Crank that the Cylinder was Run on ? It might have been a +4 Crank and would have Porting that wouldn't work if you went back to a STOCK stroke Crank (72mm)
What Year Piston was ran in it before. '86 has the half moon cutout at the bottom of the skirt....'87-89 has the window port in the intake side.
What year is the Cylinder ? Look in the Intake and if it has two vertical supports its the '87-89.....if it's a big opening with two smaller openings to the bottom left & right....it's an '86.
'86 on the LEFT....'87-89 on the RIGHT
(http://forums.trx250r.org/vbulletin_imports/150_2175_2017-04-18_2566.jpg)
