Other ATV\'s => Other ATV's => Topic started by: xTHUNDERCATx on June 13, 2014, 06:30:35 PM
Picked it up the other day, previous owner did not know ANYTHING about the bike. It fired up and sounded fine when i first got there then shut down and wouldnt start again. Took about 12 hours and a sun burn to figure out a previous owner broke a piece off of the female end of the connector on the stator wiring, The piece jammed into the male end so the two sides couldnt be connected properly, so naturally with their incredible wisdom they just smashed the two ends together barely making a connection. I Grabbed a pair of pliers, cleared the debris and she fired right up. A diaphragm in the carb is torn and causing it to leak so ill probably replace the carb to eliminate the stock mess there. Other then that she is staying how she sits tell after dunefest.
+6(?) swing arm
+2 a-arms
fox shocks up front
everything including plastic mounts are chromed.
ASV brake and clutch levers
Possible cam mod (He said the guy he bought it from mentioned it)
Other then that believed to be a stock motor.
Paid $2100 and got dirt and paddles with it.
(http://i60.tinypic.com/bg8txt.jpg)
(http://i60.tinypic.com/15qvz9g.jpg)
Hey! Good for you! It's not a Honda, but enjoy it the same! :encouragement:
Good to see youve got it figured out- my 2nd yfz I got a good deal on and it wouldnt tune for anything---after some digging I found a washer wedged in an intake runner in the head dug that sucker out and that bike ended up being one fast bike once I got a good tune on the thing - ive still got the washer on my key chain -- ive gotten rid of my yfz's and am all honda now --
lol im actually not a big fan of honda outside of the 250r I run all yamaha. The r is my favorite by far tho.
Im not brand specific but having all the same brand in the garage is handy for parts swapping (especially wheels)
