Classifieds => For Sale => For Sale - Parts => Topic started by: t0mmyt24 on June 14, 2014, 11:10:56 AM
Have a nice trx450r "4-stroke" drag motor bored and stroked to a 521cc fully built by RE who did an excellent job.
-5 axis cnc ported head/milled to increase compression 1.75 points -valve job with +1 ferrea intake/exhaust -High rev Kibble White dual valve springs -99mm CP big bore cylinder with 13:1 CP piston -Hotrods +3 stroker crank trued and welded with upgraded crank bearings and seals -Web cam 242 -Direct Drive lockout clutch clear lens with billet kicker -Stock trans
I just had the top end rebuilt last June and have only made it to 3 races since. The airfilter was cleaned and had fresh motor oil before each race. The compression ratio is 14.75:1, I ran VP u4.4 race fuel. The rwhp was around 70 hp. Looking to get $4000 or will trade for a stock 04-05 motor plus $2500 or a trx250r saber or puma drag motor. If interested text or call 330-330-0333.
Those Racers Edge motors are the finest built! Good luck with sale!
Thank you, it's unfortunate I have to sell it however the track I'm racing at now doesn't have a 4 stroke class therefore it's time to build my 250r for the drags!
