Classifieds => Wanted => Topic started by: bholzgen on July 11, 2013, 10:59:00 PM
Title: 400ex Hub Setup
Post by: bholzgen on July 11, 2013, 10:59:00 PM
I have lonestar +2 a-arms with factory spindles.  The ball joints are adjusted as far as they can go, and there is still too much negative camber.  I was told 400ex spindles fix this issue?  If so I would be interested in buying a 400ex front end setup.
Thanks, Blake
Post by: mx250r91 on July 11, 2013, 11:07:26 PM
Hubs won't change your camber but the spindles will...
Post by: bholzgen on July 11, 2013, 11:12:46 PM
I am aware, I typed that incorrectly.
Post by: mx250r91 on July 11, 2013, 11:39:30 PM
Ahh sorry there. I believe the 04-05 450R spindles work as well and utilize twin piston calipers.
Post by: F-Red on July 14, 2013, 10:47:33 AM
Quote from: mx250r91;3072
The 06+ work well also. :encouragement:
(http://i532.photobucket.com/albums/ee328/RideRed187/250R%20Pics%20Parts/a3cd6270.jpg) (http://s532.photobucket.com/user/RideRed187/media/250R%20Pics%20Parts/a3cd6270.jpg.html)
(http://i532.photobucket.com/albums/ee328/RideRed187/250R%20Pics%20Parts/db4ef8e4.jpg) (http://s532.photobucket.com/user/RideRed187/media/250R%20Pics%20Parts/db4ef8e4.jpg.html)
Post by: mx250r91 on July 14, 2013, 11:50:32 AM
Quote from: F-Red;3667
Good to know! For some reason though the 04-05 sticks in my mind as being more desirable?
Post by: bholzgen on July 14, 2013, 12:02:04 PM
What should I expect to pay for a mint set?
Post by: fearlessfred on July 14, 2013, 12:54:14 PM
I have a set  Im not using don't know what there worth .shipping from dan would be cheaper
Post by: F-Red on July 15, 2013, 12:57:53 PM
Quote from: mx250r91;3672
I do believe the 04-05 have a better turning radius. Not 100% positive on that. Better geometry, in some area. My type of open trail and woods riding, doesn't require that advantage.
Quote from: bholzgen;3673
For an 07 TRX450R, I paid $150.00 for everything needed.
Post by: JoePA on July 17, 2013, 02:16:37 PM
I have a set of 400ex spindles at the house somewhere. I'll look for them if you are interested. it's just the spindles...no hubs or calipers.
Post by: nastyracing on August 02, 2013, 04:04:40 PM
pm being sent I got what you need
Post by: sameltoe on August 02, 2013, 09:43:37 PM
Don't forget you can use the yfz calipers (dual piston) with the 400ex stuff. I got a fresh black pc set of 400 hubs if you piece it together...cheap.
Post by: lrd_250r on August 03, 2013, 11:27:11 AM
I just put the 06 trx450r front end on. I had leftover 450r parts and i didnt want to buy parts
Post by: bholzgen on August 04, 2013, 01:48:44 PM
Purchased a set from Dan Hung.  Thanks for the help guys!
However after installing the new 400ex front end parts I still have negative camber.  Come to find out, 3 of the four ball joints on my +2 LSR arms are short.  One is longer, allowing the camber to be where I want it.  Does anyone have a longer upper ball joint?  I have no idea what kind of ball joints they are either... I will try to get photos.  Going to need help with this one guys!
Post by: bholzgen on August 04, 2013, 01:56:10 PM
Here is a photo.  I can post better photos of the ball joints if needed.
(http://i1214.photobucket.com/albums/cc499/12bholzgen/download_zpsc9f28a0d.jpg) (http://s1214.photobucket.com/user/12bholzgen/media/download_zpsc9f28a0d.jpg.html)
Post by: jamieg45 on August 04, 2013, 02:07:48 PM
Take the ball joints out bud and take both a long and short to NAPA and they will help you out and its much cheeper than buying from LSR. Unles you talk to spiretaces about your lsr ball joints, he mite be able to see what they cost for you since they are his neighbor now where he lives
Post by: bholzgen on August 04, 2013, 02:20:09 PM
NAPA would stock these things?  I had no idea..
Post by: jamieg45 on August 04, 2013, 02:54:33 PM
Yah but they were moog brand but I don't remember the part number
Post by: jamieg45 on August 04, 2013, 07:24:05 PM
Quote from: danhung11;7251
Part Number on box: 274-9142
Thanks man
Post by: brewer_brewer on August 05, 2013, 02:05:22 AM
04-05 450r spindles are the best bet in my eyes, for geometry and being able to find them cheap
A tip that might help you with the ball joint/camber issue:
Take the nut off of the lower balljoint (the one on the outside of the arms closest to the tire)  run the balljoint all the way in and just use the nut on the inside of the a-arm (side closest to the frame)
This will pull the spindle closer to the a-arm on the bottom and give you a lot more adjustability out of the top balljoint
Also the closer the ball joint is the a-arm (more threads penetrating the arm) the stronger it is
