Workshop => Carburetor, Intake, and Exhaust => Topic started by: Allison#51 on July 26, 2014, 09:18:00 PM
Title: CR or TRX rad valve?
Post by: Allison#51 on July 26, 2014, 09:18:00 PM
Can anyone tell just from the pictures if this is a cr or trx rad valve?
(http://i603.photobucket.com/albums/tt116/Allison55/Mobile%20Uploads/CAM00604.jpg) (http://s603.photobucket.com/user/Allison55/media/Mobile%20Uploads/CAM00604.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/Mobile%20Uploads/CAM00605.jpg) (http://s603.photobucket.com/user/Allison55/media/Mobile%20Uploads/CAM00605.jpg.html)
I'm guessing it's the cr because it has a pretty sharp angle and it's short just need someone to confirm that. It doesn't match up to my carb very well..
Post by: rk88r on July 26, 2014, 11:11:59 PM
Looks like a cr to me. I think the cr number is 0-2a and the trx is o-4a something like that. Is that a smart carb?
Post by: dlunn on July 27, 2014, 10:01:44 AM
It looks like a CR.
Post by: 2ndmoto on July 27, 2014, 01:29:56 PM
Definitely a cr style. Trx has a longer neck. Boyesen made a 02A and a 02B for the CR. If I recall correctly, it is stamped on the side of the cage, in between the reeds, so you would need to remove the cage from the cylinder to see it.
The CR rad valves were designed for 38mm carbs while th TRX rad valves were designed for 34mm carbs. CR style definitely works better on modded trx cylinders
A 3/8" reed spacer will correct the alignment problem you are having.
Best regards
-Jason
Post by: Allison#51 on July 27, 2014, 10:00:27 PM
Alright thanks guys! Another instance where I bought something that was listed incorrectly.. Lol Yeah it's a smartcarb rk88r. I guess I'll pull the reeds off and get a reed spacer I didn't wanna have to run one but I do wanna run the cr valve if they were designed for the 38mm carbs, I never realized they were that different other then the length and angle of the neck. I also need the boot to go from the reeds to the bigger carb. Maybe I could just get a radiator hose that's the correct size and make it a little longer..
Post by: 2ndmoto on July 27, 2014, 11:16:20 PM
You can buy the boot from boyesen. They fit nicely into the grooves on the rad valve and carb.
http://www.boyesen.com/rad-valve-replacement-boots-10.html
Best regards
-Jason
Post by: udontknowme on July 28, 2014, 01:43:13 AM
spacer might not be  a bad idea. some them rad valves sit so far in i think they hinder the boyesen ports
Post by: JesseA420 on July 28, 2014, 05:19:39 PM
i know for a fact stock cr intake is at such a sharp angle it runs the carb straight into the frame rail. if this has the same angle, it will take more than just an intake spacer to make the carb point to in between the frame rails. i just sold it and got the correct trx intake.
Post by: Allison#51 on July 29, 2014, 09:51:29 PM
Quote from: JesseA420;40013
Yeah I think your right. I wish we had more options for carb to airbox boots and it wouldn't be as difficult to get everything to line up.
Post by: 2ndmoto on July 29, 2014, 10:16:15 PM
I ran the rad-02b with a 3/8 spacer into a 38mm pwk on both an OEM and prox cylinder. This was on stock frame using an 89 airboot and stock air box. Didn't have a problem with alignment.
I have never tried running the OEM CR250R intake manifold, which is what I think Jesse is referring to.
Best regards
-Jason
Post by: Allison#51 on July 29, 2014, 10:24:01 PM
Quote from: 2ndmoto;40101
Best regards
-Jason
Did the airboot rub on the frame though? Thanks
Post by: 2ndmoto on July 29, 2014, 10:36:25 PM
It was years ago and the only thing I have left of the setup is the airboot. I can look an see if it is worn from rubbing on the frame...however that will have to wait until this weekend. I dont recall that ever being an issue.
But, thinking more about it, I am pretty sure it was a 1/2" reed spacer
Best regards
-Jason
Post by: 2ndmoto on August 03, 2014, 02:43:43 AM
Found the airboot. I don't see any wear marks on it. Ran a few seasons with this setup. I think you are good.
Best regards
-Jason
Post by: Allison#51 on September 18, 2014, 09:36:29 PM
Found a trx rad valve (04A) so I did some comparisons with my cr valve (02). Hopefully this will clear some things up (http://i603.photobucket.com/albums/tt116/Allison55/CAM00647.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00647.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00633.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00633.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00634.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00634.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00635.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00635.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00636.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00636.jpg.html)
Post by: Allison#51 on September 18, 2014, 09:40:20 PM
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00638.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00638.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00639.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00639.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00641.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00641.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00643.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00643.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00645.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00645.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00646.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00646.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00650.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00650.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00651.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00651.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00652.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00652.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00653.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00653.jpg.html)
Post by: Allison#51 on September 18, 2014, 09:46:08 PM
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00655.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00655.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00656.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00656.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00657.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00657.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00658.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00658.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00648.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00648.jpg.html)
(http://i603.photobucket.com/albums/tt116/Allison55/CAM00649.jpg) (http://s603.photobucket.com/user/Allison55/media/CAM00649.jpg.html)
Post by: Allison#51 on September 18, 2014, 10:04:19 PM
I found that there wasn't really more then 1mm difference in any of the openings. The center support is a little wider and extends further on the trx valve. The reed petal mounting is all the same. I don't see any reason why with a little bit of work the trx valve won't flow as good as the cr without having the fitment issues. I can go back through and label which one is which if it's too hard to tell. Let me know if you want to see any more pictures of the trx valve because my plan is to start carving away at it soon. I'm still curious if there is any differences between the 02 and 02B valves. I'm gonna guess that the 02B is a newer version of the 02 and the 04A is an updated version of the 04.
