Workshop => Engine and Bottom End => Topic started by: bkstoffe on September 22, 2014, 09:15:10 PM
Ok ive got "chunky" bearings in the clutch actuator well on second set of cases Im building. I have two questions..
1.) what is best way to pull lower bearing out of the case? my bearing puller doesnt reach in that far..
2.) where can i get the replacement bearings? on Service Honda's site it says unavailable. I guess I can try to match them up at a bearing house? Hoping someone sells them specifically for this application though.
thanks!
I can't tell you how to pull the bearings but as far as replacement bearings go you can go on partzilla.com or motosport.com for replacement bearings. If your talking about the bearings that go to the clutch actuator arm partzilla is where I bought mine and all the other bearings that go in the engine cases for my rebuild.
I had to replace mine as well a year ago.. I got replacements from sire sponsor Boss bearing on .net
Muthahucker, what did you use to pull lower bearing out?
Thanks
I had to get my local engine shop to get them out for me. I have no idea how they do it. Sorry.
