Classifieds => Wanted => Topic started by: j@y on October 11, 2014, 01:11:16 PM
Looking for a top engine mount for the head or I might have to go the ESR route.
I have one for a 86 frame, it could use paint or powder but you pay shipping and it's yours. I don't use a head stay on my bike.
Hey thanks mickkey! Do you know if it'll fit a 88/89 frame or are they all the same?
No problem, I'm not sure I think they are the same but I'm not 100% sure, maybe try asking on the forum. I'd hate to send it and it not fit.
I found one off an 88 with front mounts and fresh powder but thanks again anyhow.
Are you running a spacer plate? If so a stock one won't work
Darnit! Yes and no. I'll be running esr cases with the deck height for longrod so pretty much the same thing.
All years are the same. You should be able to slot the holes with a file and get it mounted up. Otherwise some use a smaller bolt to make it through the holes.
Esr head should be slotted I think
Cool thanks puma. I think it is sgb318 I'll have to check when I get home
