Workshop => Engine and Bottom End => Topic started by: 05450r on July 15, 2013, 12:03:46 AM
Title: Long cylinder studs
Post by: 05450r on July 15, 2013, 12:03:46 AM
Where do I get longer cylinder studs for Pro-X cylinder with spacer plate? Seen Esr has them but I only found them as a kit with the spacer plate. Thanks!
Post by: rk88r on July 15, 2013, 12:56:50 AM
In think certain cr 250 studs are the ones to use. Sorry I can't remember which year.
Post by: 05450r on July 15, 2013, 01:11:33 AM
Thank you,that gives me something to go by,I should be able to find the lengths with a little searching.
Post by: Bigred on July 15, 2013, 02:54:57 AM
02 cr250 studs they are pretty cheap think like 2 buck a piece I paid from Honda dealer
Post by: Morse250r on July 15, 2013, 05:37:29 AM
heres the honda part #929010080-0B on the 80 mm studs
Post by: rablack21 on July 15, 2013, 08:05:07 AM
ESR would probably sell you the studs individually if you called them.
Post by: 05450r on July 15, 2013, 09:44:35 AM
Thanks guys!!!
Post by: 05450r on July 25, 2013, 09:47:12 AM
Ended up using Honda p/n 92900-10055-0B. Found a guy in MO off of ebay that had some in unopened packages. My local dealer said the 0080's were discontinued. Not sure if the 0055's are or not but they worked perfect! Im using a thinner spacer plate as my piston comes out of the cylinder,but these would work fine with a normal spacer plate. Bad pic but it should give a good idea of how the fit. I was still able to use a ground down wrench to tighten the nuts(http://i832.photobucket.com/albums/zz242/04450r/photo2_zps86a03536.jpg)
Post by: rsss396 on July 25, 2013, 09:59:09 AM
I think the cr500 studs work but there is 3 sizes, all the fronts are the same but they had 2 differant length rear studs
Post by: 05450r on July 25, 2013, 10:17:46 AM
Correct. Seller had these listed as 92-01 Cr250. There is also 0055-3B that I found to,which I forget what those fit. Also I looked around some more on Esr's site and found where they have the studs listed seperately. Some people back the stock studs out approx. 3-4 turns also,not my choice..lol..
Post by: Fear250r on July 25, 2013, 03:01:31 PM
The stock studs can be twisted out to get enough to clamp down also.  3-4 turns out, there's plenty of room.
