Workshop => Suspension and Chassis => Topic started by: muthahucker on November 22, 2014, 12:53:25 PM
Title: 86 Frame
Post by: muthahucker on November 22, 2014, 12:53:25 PM
If I put aftermarket A-arms on my 86 frame that are 1" forward and then get an aftermarket swing arm that is 1" shorter like the 88-89 swingarm, will I then get the same stance from my 86 frame as the 88-89 frame with the shortened swingarm, or are there still some major frame dimension differences.  Ive got the +1 front A-arms but still using my stock 86 swingarm.  Seems to be a bit long in the woods.
Title: 86 Frame
Post by: Hawaiiysr on November 22, 2014, 01:10:21 PM
This is the exact same set up I have on my 86. 1" forward arms and a 89 length swing arm. Wheel base wise yes you should have the same dimensions. I didn't think the -1 swing arm would make a huge difference but it did. I like it a lot as its easier for me to whip the rear end around on the track.
Title: 86 Frame
Post by: fearlessfred on November 29, 2014, 06:53:00 PM
I don't think you would need 1 inch forward arms to make the wheel base the same.86/87 had a 51 inch wheel base and the 88/89 had 49.8 wheel base.I think the 1 inch forward for the 88/89 is another internet myth.
