Member Services => Introductions => Topic started by: Eschonda on July 20, 2013, 01:32:48 PM
Title: checking in from .net Eschonda
Post by: Eschonda on July 20, 2013, 01:32:48 PM
Dropping in from .net site.. I was a periodical poster there, and missed whatever prompted this new site and whatever friction there was.. Someone want to fill me in ,via PM as to what that was over?  ..Anyway,looking forward to continuing to contribute on here as a suspension shop, and provide service to those looking to maintain and upgrade their shocks..
Post by: Fear250r on July 20, 2013, 01:49:31 PM
Welcome aboard Esch. Nice to have you here.
Post by: fearlessfred on July 20, 2013, 03:15:48 PM
you said it all in one of your posts on the net about god . I sent you an invite under another user name .glad you made it over and Im glad your here
Post by: havinnoj on July 20, 2013, 05:07:28 PM
Nice to have a shock builder on here. You have any experience and opinions of the Axis PRS system? I have a front pair I need to rebuild completely and am interested in PRS for dunes.
Post by: Pumashine on July 20, 2013, 09:50:24 PM
Quote from: Eschonda;4780
I missed whatever prompted this new site and whatever friction there was.. Someone want to fill me in
It might have something to do with a certain post about questioning gods advice. Wait a minute, it just disappeared along with all my pre-carl buddy's posts implying there are more than one choice other than the way Honda does it choice BSDT uses. Really does not matter, its over and we all welcome you to the new Best TRX250r site, Enjoy!!!!
Post by: pantera1975 on July 21, 2013, 09:11:32 AM
Welcome to the board. Great shock builder,I couldn't be happier with the service and performance of my new shock.
Post by: Eschonda on July 21, 2013, 09:12:36 AM
Quote from: havinnoj;4820
I have not touched a set of Axis PRS shocks yet. So don't know exactly what they have. But what I've seen on the web, from their cut-away pic's, it's not new technology though. They  pretty much took a page from others playbook though it appears. To my knowledge, Ktm had it first. In the UTV market Fox, has their version of the same thing, with  "bottom-out Cup" technology. In the big -boy arena, of off-road racing, King Shocks applies the same theory with their internal by-pass coilovers.. They all use 2 internal shock pistons instead of the traditional 1. All of them apply the theory that with the main piston can now be valved for a softer initial ride, and at the bottom portion of the stroke , a second piston engages a secondary internal smaller diameter shock wall (think upside down cup) at the top of the shock body. This second piston is valved significantly stiffer, to act like a bump stop. The other part that most of these shocks use, is the free bleed circuit that is controlled by a tapered needle(much like carb needles). the length and thickness(thinner or fatter)of taper determine how soon and how fast the circuit is closed as the shock is bottoming out. This needle is threaded into the top cap of the shock (center of the upside-down cup) and engages the hollow center of the shock shaft to close the free bleed circuit as the shock compresses. ( hence Kings name for internal "bypass"..  Hope that helps explain..
Post by: Sky on July 21, 2013, 11:52:15 AM
Speaking of King Shocks Esch, is there a set up for available for 250r's or Banshee's? By bro-in-law was told he can get Kings made for his banshee? Have you ever heard of this?
Post by: Eschonda on July 21, 2013, 08:45:51 PM
Quote from: Sky;4903
 A buddy of mine had a shop fabricate some long travel arms for his Yamaha Raptor. They then ran king shocks.. They were 2.0 shocks , and pretty big and heavy.. Possible?.. probably.. Would I recommend it?.. probably not.. For the smaller platform of the ATV, the 2.0 size shock up front is overkill, and adds un-necc. weight. because of the huge 2.5"ID size spring you are forced to run.. The only application where I'd see a merit is desert racing, where shock fade at mega speeds and rough terrain becomes an issue with oil breaking down because of temps..
