General => Lounge => Topic started by: lrd_250r on February 15, 2016, 05:10:49 PM
Title: Need some Identification help
Post by: lrd_250r on February 15, 2016, 05:10:49 PM
Guys this durablue axle came with my atc250r project, can someone tell me if it's for a 1985 or 1986 atc250r(http://uploads.tapatalk-cdn.com/20160215/413b651eae525d8159bbe517fd2e9607.jpg)(http://uploads.tapatalk-cdn.com/20160215/3045fce07b42977fa8ba761e86f7257e.jpg) and which model axle it is?
Sent from my SM-G900V using Tapatalk
Post by: lrd_250r on February 15, 2016, 05:11:20 PM
(http://uploads.tapatalk-cdn.com/20160215/0584a359f8d0af5b14b287619cc2ae19.jpg)
Post by: dp250r on February 16, 2016, 10:09:40 AM
My guess is it is for the 85 250r .Because the rear sprocket mounts on the outside of the hub.The 86-89 sprockets mount on the inside of the hub.The 85 rear axle will not work on the 86-89  .But the 86 and up axle will work on the 85.Im not sure on wich durablue it is.
Post by: lrd_250r on February 16, 2016, 02:00:24 PM
Thanks. All I need is a the 1985 carrier and this thing will be a roller
Post by: The_Steve_Man on February 18, 2016, 10:58:15 AM
Is it going on an 85? You cant put an 85 carrier in an 86 up swingarm. Too small. You might be able to get a sprocket hub from durablue for the 86 .
