Workshop => Suspension and Chassis => Topic started by: PNWrider on May 18, 2016, 02:18:37 AM
What do I use for mounting the front of the skid plate to the frame
(http://forums.trx250r.org/vbulletin_imports/71_7774_2017-04-18_9726.jpg)
I think they usually have a small piece of channel that spans the width of the frame to work as a clamp. You could also cut some tubing to make a crush collar for the front through bolts to keep the channel from collapsing when you tighten the bolt. Be sure to use nyloc's too to keep it from turning into a pole vault.
(http://forums.trx250r.org/vbulletin_imports/24_7775_2017-04-18_9226.jpg)
(http://forums.trx250r.org/vbulletin_imports/24_7775_2017-04-18_3448.jpg)
This looks way better than what I suggested.
Thanks for the info guys, got a piece of steel for now since I'm racing this weekend. I'll definitely try to do what you did croat1, that looks really good
