General => Projects => Topic started by: havinnoj on June 18, 2016, 06:16:08 PM
This build thread is a bit overdue.
Been toying with the idea of building a big Puma for the dunes over the last couple of years. No donor bottom end was supplied so the majority of bottom end parts are NOS or OEM take-outs - definitely NOT a cost effective way to build a motor!
Started with a set of OEM ATC cases (complete with VIN stickers), courtesy of [MENTION=54]Redred55[/MENTION]:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/02F016B2-C482-4DA8-B0F2-58136E407E71.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/02F016B2-C482-4DA8-B0F2-58136E407E71.jpg.html)
Puma top end shows up @ Hybrid Engineering:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/D9DB21D2-5E57-4182-9C38-26C790FF9C57.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/D9DB21D2-5E57-4182-9C38-26C790FF9C57.jpg.html)
Had Crank Works (http://www.crankworks.com) build me a +6mm from OEM halves. Now for the crank porn:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/511EF829-87D5-4063-957C-C68C48E4FF14_1.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/511EF829-87D5-4063-957C-C68C48E4FF14_1.jpg.html)
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/259B944C-0ECB-406E-8BB0-CCD4F57F6A69.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/259B944C-0ECB-406E-8BB0-CCD4F57F6A69.jpg.html)
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/E31DB5C3-44BC-4EA4-9290-26CFEC575F9D.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/E31DB5C3-44BC-4EA4-9290-26CFEC575F9D.jpg.html)
Making progress:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/C70E9C70-5ED4-48D1-A7E6-CBE0BC5D50F8.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/C70E9C70-5ED4-48D1-A7E6-CBE0BC5D50F8.jpg.html)
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/1E847BC1-1A2C-4458-AD04-053AED35676C.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/1E847BC1-1A2C-4458-AD04-053AED35676C.jpg.html)
Assembly begins:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/3B359833-CD5A-42C2-B9D4-95D2ACAC2351.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/3B359833-CD5A-42C2-B9D4-95D2ACAC2351.jpg.html)
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/6E502C88-5E94-4453-82D3-BFED7A61214C.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/6E502C88-5E94-4453-82D3-BFED7A61214C.jpg.html)
Now just waiting on [MENTION=74]traxman[/MENTION] to finish polishing the cylinder :lol:
^^^ join the club!! :)
Looks great when you start. Be sure to get lots of pics after assembly. The bottom end polish will only last so long, so savor it while its still shiny.
I saw that crank at Pete's, when I dropped off my motor last month. Pretty impressive workmanship, with all the heavy metal they added and that massively reworked rod.
What rod r u using? Looks big
what rod r u using? Looks big
yz490
Looks amazing can't wait to see finish product!!
No over ride? This is the one going on the LSR hillshooter right?
No override. 2 different Puma's. This motor is going in my dune bike. The LSR hillshooter already has a Puma in it. :D
Killer build! Puma dunner is on my wish list.
What pipe and carb are you gonna run on it?
Yes it really is gorgeous. I took it to Crank Works personally with I was in AZ and checked on it a handful of times to make sure it was exactly as desired. There was a ton of work involved on their end and the $1300 bill reflected that!
Thank you sir!
LED Puma pipe to start and 40.5 PWK carb.
Cylinder received some polishing love from [MENTION=74]traxman[/MENTION], Cascade to finish up the head:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/7BFFFEBF-D2D6-4CCF-9B4D-23C29B59000C.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/7BFFFEBF-D2D6-4CCF-9B4D-23C29B59000C.jpg.html)
And [MENTION=276]ledperformance[/MENTION]'s gorgeous Puma pipe:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/15281892-1883-4205-AF7E-ABEC9FD8E586.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/15281892-1883-4205-AF7E-ABEC9FD8E586.jpg.html)
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/B64E6D53-306D-4E87-B488-F08792BA5F33.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/B64E6D53-306D-4E87-B488-F08792BA5F33.jpg.html)
Sweet!
amazing!
Nice view of the river!!
sweet project. hopefully the crank doesnt give you any trouble with the lower pin being moved so high on the webs
My plus 6 as had no issues with the crank.
thats good. hopefully it stays that way. when you thin out the material above the pin it can get alittle sketchy
Getting close...
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/D50E6922-B71F-49A7-A944-8AF7CA63B501.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/D50E6922-B71F-49A7-A944-8AF7CA63B501.jpg.html)
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/513A3E53-7BFF-4C50-AEC5-23444E139CEB.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/513A3E53-7BFF-4C50-AEC5-23444E139CEB.jpg.html)
I like how you left my engine out of the pics! :)
I would take it Pete does not take pics of all the motors?
If you say so.
(http://i66.tinypic.com/2l8w0g8.jpg)
GOOD LORD!!!!! Never mind internet porn...
Should see all the CP-equipped motors in the shop!
And the drag car
I got the drag car covered.. ;)
(http://img.photobucket.com/albums/v472/bigmike11554/Mobile%20Uploads/2016-02/C34AFFB2-A3DA-4B5C-9CAA-0B0C5E537A3C.jpg) (http://smg.photobucket.com/user/bigmike11554/media/Mobile%20Uploads/2016-02/C34AFFB2-A3DA-4B5C-9CAA-0B0C5E537A3C.jpg.html)
(http://img.photobucket.com/albums/v472/bigmike11554/Mobile%20Uploads/2016-02/B715AE15-1B0D-4EB4-BDBD-096E863E928C_1.jpg) (http://smg.photobucket.com/user/bigmike11554/media/Mobile%20Uploads/2016-02/B715AE15-1B0D-4EB4-BDBD-096E863E928C_1.jpg.html)
He's got mine there somewhere
Nice car [MENTION=875]Big_Mike[/MENTION] - you should throw up a thread on that sometime.. would love to know more about it!
And it's done.. minus a couple small things:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/D70802F5-F2A2-45E3-B72F-0A045C900BF5.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/D70802F5-F2A2-45E3-B72F-0A045C900BF5.jpg.html)
Looks awesome. I bet it's going to put a smile on your face!
did you find those hinson clutch components or have you been hoarding them since they were still being made lol?
This motor has no Hinson components - all OEM with a Slingshot. But I do have a couple spare Hinson 8 plate setups and a bunch of extra bling:
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/250%20Parts/5DD52D08-20DC-40DE-BFA9-BE689338BB33.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/250%20Parts/5DD52D08-20DC-40DE-BFA9-BE689338BB33.jpg.html)
You going to tease the guys or let some of it go?
Silly Jared.. you know better than to ask that question! :lol:
Full disclosure: both Merrell waterpump covers are now used as are a couple of those Hinson plates - only have 3 plates now that aren't used.
Wow looks amazing, any idea what kinda hp this will throw down?
Thanks. This is setup for a midrange dune motor. At some point I'd like to get it on a dyno and test a few things.
Damm! That's sick
Mike, I think my turbo could fit inside the inlet of yours. I got nothing on that thing. Birds and small children beware
That's only the 76mm, its setup for a 106mm!
:(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/250%20Parts/5DD52D08-20DC-40DE-BFA9-BE689338BB33.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/250%20Parts/5DD52D08-20DC-40DE-BFA9-BE689338BB33.jpg.html)
Wow, just wow. I don't even care about riding, I will just look at pics all week end :rofl:
Rust check
(http://i1215.photobucket.com/albums/cc510/havinnoj/250R/443%20Puma%20250R/E1A90A17-2251-4A5C-88A2-F2DA47DBB057.jpg) (http://s1215.photobucket.com/user/havinnoj/media/250R/443%20Puma%20250R/E1A90A17-2251-4A5C-88A2-F2DA47DBB057.jpg.html)
