Riding Styles => XC => Topic started by: Onski326 on July 10, 2016, 09:46:39 PM
Well that was a fun and interesting race to say the least. Weather was crazy! Started out at 100+ temps, sunny and no breeze and with about 3 laps complete, the bottom fell out. Temps dropped 20+ degrees, wind whipped up and the sky opened up and it started to pour! It was so hard to stay cool before the race and after it was over, I sat inside my truck for 15 minutes with the heater on full blast trying to get some warmth back in my bones. Didn't see that one coming. lol
So I grabbed 2nd on the holeshot and ended up 2nd in my class. The 250R did amazing but I'm still thinking she needs some more power. I got into a drag race about 5 laps in after the holeshot with a built LTR450 and he edged me out. Course it was pretty greasy out by then but I still can't help but think I need more power. :biggrin-new:
I hope you enjoy the vid of the first lap and as always, if you're in the area, please stop in for a race. I'd be more than happy to show you around!
[video]https://youtu.be/Q_M52bTxigg[/video]
Big bore that whip. Hawk and ballance slayed on some 330s.
I've got an ESR310PV high comp in it right now. It does well against modified 450's but this guys LTR has a big bore, high comp, Yoshi, cherry bomb ported and cam'd motor. He's got a few $$$ in his build. His was hooking up a lot better than mine when the rain started too. I had too much air in the tires and was sliding all over the place. My bad. That's what I get for not checking the radar but weather man that morning said the day was to be +100 with a 10% chance of rain so I set up for a very dry, hard pack track and it was initially.
I wouldn't be too hard on yourself. Sounds like you did really well. Even if you had a bigger motor, the edge would still go to the 4 stroke in muddy or wet conditions. That's just the nature of the two beasts. Less air pressure would definitely help in that case though. So would a flywheel weight. Good job sir!
Big bores make more torque, and have more inertia. You can lug them a gear high and roll out of the corners. They become like a 4 stroke. Takes a bit more finesse than riding a big 4 stroke, but you would be amazed at the difference of how well a big bore runs when properly setup.
I have a big bore, and while I agree with some of what you said, the big bore is still lacking against a 4 stroke in wet and muddy conditions. I just raced a super muddy race this weekend, and it was very evident that the 4 strokes were having a much easier time getting through the mud. Just my observation.
I've been eyeing the 350 bb for some time and I think after this season I'm going to have to pull the trigger on it. I've done about all I can to the 310 to squeeze power out of it and it's probably just time to bite the bullet and move up to a 350.
Sounds like you are going down the progression path that I did. I will say this just so you can keep it in mind. The 350 will have quite a bit more power, or even consider a 363 stroker. Just keep in mind that it will guzzle the fuel in comparison to the 310. My 363 is a super thirsty girl. You will also potentially need a big bore style pipe to go along with it. Not discouraging you, just a few things to consider as you move forward.
