Workshop => Engine and Bottom End => Topic started by: Bharris on July 26, 2016, 11:16:16 AM
I really need your input if you have any - this is my first time with opening the engine - so far it's been lots of fun!
I have no clue what to expect when I start pulling the gears, and gear mechanism. I know that something is wrong here, but I don't know what. Although the bike will shift, the shifter gets hung at the very top of the up-motion, then only snaps into the next gear with a lot of force and a harch snap. It gets a bit easier as you move up the gears, but it's definitely not a good thing.
Now that the engine is one my bench, it's stuck in first gear and I don't have the leverage to move through the gears in hopes to find where the binding is.
- What should I look for in regards to worn out parts ( I only know about the forks and drum - should I be looking also for something else)?
- Again, this is my first time is a motorcycle case - ever. I'm confident that I can do the work, but I just have some questions
As always - you guys rock! I couldn't have gotten this far.
