Quad of the Month => QOTM - Sponsored by Eddie Sanders Racing => Topic started by: Fear250r on August 19, 2016, 10:16:10 PM
Hey everyone, sorry. Should've posted this earlier.
September is an open month. Get your entries in ASAP!!
Jesse
(http://uploads.tapatalk-cdn.com/20160820/b5fc44588d595a39ffdb834c5ecb7800.jpg)(http://uploads.tapatalk-cdn.com/20160820/d771a807bb3a2cc500c3cdb1c2ade621.jpg)(http://uploads.tapatalk-cdn.com/20160820/84a3c048caf6fc4d77c378b9aec6a4cd.jpg)(http://uploads.tapatalk-cdn.com/20160820/3031b14b6818b29a4f35b992449750f2.jpg)(http://uploads.tapatalk-cdn.com/20160820/9ae03d3e0cc30351d75b04d0e4bce3a0.jpg)(http://uploads.tapatalk-cdn.com/20160820/7c23cad6bb64479e54094f9a25dc78e1.jpg)(http://uploads.tapatalk-cdn.com/20160820/c1f8c87b75e77cdeca3d3783c7bdc847.jpg)(http://uploads.tapatalk-cdn.com/20160820/710c4488e498de0f9587f31da8277fe7.jpg)(http://uploads.tapatalk-cdn.com/20160820/2285b68a32ab34f18f2595981fd8c4a4.jpg)(http://uploads.tapatalk-cdn.com/20160820/1d9728dcd3112efbb52e950592683db5.jpg)(http://uploads.tapatalk-cdn.com/20160820/ef6097db34236e5373ae34a21b725fd9.jpg)(http://uploads.tapatalk-cdn.com/20160820/ff03bcae36344c457d39da37dae10f2a.jpg)
Frame: 2008 trx450er
A Arms: Laegers +2 sport a arm's
Swingarm: oem
Steering Stem: oem
Axle: +2 aftermarket
Carrier: oem
Locknut: oem
Hubs F|R: oem
Bars: Renthal fatbars
Brake/Clutch Lever: asv
Grips: renthal
Foot Pegs: Roll Design / IMS
Bumper: oem wrinkle black finish
Grab Bar: Houser
Front Shocks: oem
Rear Shock: oem
Brake Lines: Streamline red steel braided
Rotors F|R: oem
Rims F|R: oem black
Tires F|R: oem front / holeshot rear
Body: 08 trx450r
Plastic: 08 trx450r
Graphics|Seat Cover: 08 trx450r
Fuel Tank: oem
Engine|Drive System: 86 trx250r 310 big bore
Cylinder|Head: ESR 310 big bore trx9 porting
Bore & Stroke: 72mm bore
Displacement: 310cc
Carburetor: 39mm keihin pwk
Reeds: cr250
Air Filter|Box: k&n direct mount
Pipe|Silencer: ESR trx11
Clutch|Plates: Barnett basket / driveline performance plates
Gearing F|R: oem
CDI|Killswitch: oem trx250r
Cooling: oem trx450r radiator
Other:
(http://forums.trx250r.org/vbulletin_imports/1598_8096_2017-04-18_20.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8095_2017-04-18_9648.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8088_2017-04-18_5071.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8089_2017-04-18_9280.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8090_2017-04-18_8653.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8091_2017-04-18_6260.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8092_2017-04-18_3306.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8093_2017-04-18_1464.jpg)
(http://forums.trx250r.org/vbulletin_imports/1598_8094_2017-04-18_5381.jpg)
Frame: stock 86
A Arms: stock 86
Swingarm: stock 86
Steering Stem: stock 86
Axle: lsr
Carrier: lsr
Locknut: stock 86
Hubs F|R: stock 86
Bars: renthal
Brake/Clutch Lever: stock 86
Grips: scott
Foot Pegs: alba pro peg
Bumper: alba 450r
Grab Bar: armadillo drop
Front Shocks: 450r reworked to 250r specs
Rear Shock: stock 86 pep conversion
Brake Lines: ss
Rotors F|R: stock replacement
Rims F|R: itp and stock goldies
Tires F|R: itp xc 21x7x10/20x11x9
Body:
Plastic: maier race cut
Graphics|Seat Cover: custom made ddr slapp/ factor fx seat cover
Fuel Tank: stock 86
Cylinder|Head: stock 86 bhp ported /stock reworked for 110 by bhp
Bore & Stroke: 72mmx72mm
Displacement:295
Carburetor: kenhin 38mm pwk a/s
Reeds: vf2
Air Filter|Box: k&n outer wears and outer wears lid stock box & snorkel
Pipe|Silencer: esr trx6 & esr silencer
Clutch|Plates: Barnett basket and components/ 89 update/ cliegh mod
Gearing F|R: renthall 14/39
CDI|Killswitch: dynatek adjustable 2001 cr250r set on curve #2/ 2001 cr kill switch
Cooling: Api 3 core oversize
Other: 2001 cr250r ignition/ complete rebuild all body and engine bearings and bushings using oe components
Built to be a sleeper and look like a stock/lightly modded quad. Built from a frame, and a junk motor and cases, and peiced together from ebay and trx owners for life. A full resurrection from the dead and parted.
Chassis/Suspension/Controls
Frame: stock 86 gusseted
A Arms: leagers +2 long travel
Swingarm: lsr stock length
Steering stem: houser
Axle: lsr +2 +4
Carrier: rad double row
Locknut: rad antifade
Hubs F/R: stock
Bars: rental fat bars CR bend
Brake/clutch lever: stock, msr
Grips: spider
Foot pegs: AC pro peg
Bumper: AC
Grab bar: DG
Front shocks: Elka long travel quad rate
Rear shock: stock, rebuilt by pep
Brake lines: stock
Rotors F/R: stock
Rims F/R: Omf reinforced
Tires F/R: 20" holeshots 18" maxxis RAZR
Body:
Plastic: silver full bore
Graphics/seat cover: DR number backgrounds seat cover by custom camo seats
Fuel tank: stock 86
Engine/Drive system:
Cylinder/head: Duncan racing PC 2000
Bore/stoke: 68.5mm x 72mm
Displacement: 265
Carburetor: 38mm mukini ESR tmx
Reeds: boysen
Air filter/box: uni w/ outerwear stock box no lid
Pipe/silencer: ESR trx 5 pipe and silencer
Clutch/plates: hinson basket and plates, 89 update kit
Gearing F/R: 13/40
Cdi/kill switch: stock, pro design tether
(http://forums.trx250r.org/vbulletin_imports/1760_8099_2017-04-18_4164.jpg)
(http://forums.trx250r.org/vbulletin_imports/1760_8100_2017-04-18_4413.jpg)(http://forums.trx250r.org/vbulletin_imports/1760_8101_2017-04-18_6253.jpg)
Frame:99 LSR pro peg
A Arms:LSR +3 +1
Swingarm: stock 88 polished
Steering Stem:LSR +2 +1
Axle:Lsr
Carrier: lsr
Locknut: stock
Hubs F|R: lsr/lsr
Bars: tusk 1/8
Brake/Clutch Lever: asv shortys
Grips: odi
Foot Pegs: ac pro pegs
Bumper: none
Grab Bar: unknown
Front Shocks: elka stage 4
Rear Shock: stock
Brake Lines: streamline/stock rear
Rotors F|R:stock
Rims F|R:unknown
Tires F|R:itp
Body:
Plastic: maier
Graphics|Seat Cover: fourworks
Fuel Tank: stock with maier cover
Cylinder|Head: esr
Bore & Stroke: 72x72
Displacement: 310
Carburetor:38mm a/s
Reeds: vforce 3
Air Filter|Box: esr eliminator
Clutch|Plates:stock
Gearing F|R: 13/40
CDI|Killswitch: 2000 cr250
Cooling: stock
Other:
(http://forums.trx250r.org/vbulletin_imports/1246_8102_2017-04-18_6342.jpg)(http://forums.trx250r.org/vbulletin_imports/1246_8103_2017-04-18_5428.jpg)(http://forums.trx250r.org/vbulletin_imports/1246_7757_2017-04-18_5148.jpg)
Frame: Arens
A Arms: Houser
Swingarm: Houser
Steering Stem: Houser, And Houser Wrist wrester
Axle: Prm xc axle
Carrier: Lsr
Locknut: Rad
Hubs F|R: Oem 05 450r. Oem rear
Bars: Flexx
Brake/Clutch Lever: Asv/ Magura w/Asv
Grips: Odi
Foot Pegs: Ims w/Ims heelgaurds
Bumper: Prm
Grab Bar: Dirtfirst
Front Shocks: Axis
Rear Shock: Axis
Rotors F|R: Oem/ Oem
Rims F|R: Hiper
Tires F|R: Gbc Xc masters
Body:
Plastic: FullBore
Graphics|Seat Cover: Fourwerx
Fuel Tank: Ims
Cylinder|Head: Esr
Bore & Stroke: get some
Displacement: 363
Carburetor: Pwk 40.3
Reeds: v3's
Air Filter|Box: Uni/ Oem
Pipe|Silencer: Led 350g
Clutch|Plates: Wiesco/ Oem
Gearing F|R: 13/39
CDI|Killswitch: ProDesign
Cooling: Service Honda rad/ Asi hoses/ Esr temp gauge
Other: Ccp stabilizer, GtThunder poly skid, Nacs, Walsh rad gaurd, Stealth shrouds
(http://i1347.photobucket.com/albums/p701/samw450r/20160826_182756_zpsgd0fjgyg.jpg) (http://s1347.photobucket.com/user/samw450r/media/20160826_182756_zpsgd0fjgyg.jpg.html)
(http://i1347.photobucket.com/albums/p701/samw450r/20160904_121608_zpsdq7lordv.jpg) (http://s1347.photobucket.com/user/samw450r/media/20160904_121608_zpsdq7lordv.jpg.html)
Time to bump this thread
Voting is now open.
Sorry for the delay. The "phishing site" nonsense wouldn't let me do much.
Jesse
Bump get them votes in
