Member Services => Introductions => Topic started by: Motorsports601 on April 28, 2018, 03:52:33 AM
Hello started around 1995 with an fl250 odyssey then got an 250r got a trx250r when I was 15 in 98. i wanted a banshee but they told my mom it was too much and the dealership actually wouldn't sell her it but they would sell me the trailblazer but I was done with CVT transmissions I wanted efficiency. So the performance shop in town sold us a customer's rebuilt 87 trx250r everything stock but some porting and high compression aviation gas . So as u know every modification I did was a crazy jump in performance and I was hooked throughout the years I did in order iirc fmf rev pipe, fmf ram valve, bored and modded stock carb to 36.5 I think, then upgraded to 38 air strikeer lrd high rev cdi, nology coil thing was a high revving beast. Then I think I had a bad water pump and they discovered a crack in the cylinder so rebuilt with different cylinder and it never ran the same. Changed it up a bunch of times and never got good results. I completely rebuilt customized everything then sold it and just bought it back I'm going to try replacing flywheel harness and cdi and see where that gets me.
Welcome to Org
Welcome to the site. Lots of knowledge around here to help you get it figured out. I think some pics are in order
Welcome to the site. Have you done a leak down test yet? Probably something simple. Good luck!
Welcome aboard.
welcome to the best 250r site.
John
Welcome to the site! Post up some pics of your R!
welcome. the fellas here can help you get back to where you want your R to be.
