Workshop => Engine and Bottom End => Topic started by: The norm on August 03, 2018, 10:46:44 PM
Title: Stiff clutch
Post by: The norm on August 03, 2018, 10:46:44 PM
I just replaced the clutch springs and cable and the clutch pull is extremely stiff. I had the clutch out and didn't see anything wrong. I need to get this figured out asap. Any ideas?
Title: Re: Stiff clutch
Post by: hickwheeler on August 03, 2018, 11:43:30 PM
What springs did you use
Post by: The norm on August 04, 2018, 11:09:54 AM
I ordered what I thought were oem 88-89 springs. The seller used a trick we no too well.... Oem honda packages cut open with unknown brand parts in the bag. I have tried several different springs I had with the same result every time. I guess I will pull the clutch out and see if the rod is bent. I did that when I had the bottom end apart and it looked just fine.
Post by: 2Nubs on August 04, 2018, 12:12:53 PM
Man that is dirty right there.
I hope you get it figured out quick.
Post by: The norm on August 04, 2018, 01:52:43 PM
I used my phone a friend backup plan.  Thanks broken1......
I just pulled the clutch out and reassemble it. Nothing looks out of spec or in poor condition. It has to be the springs
Post by: jcs003 on August 06, 2018, 06:58:23 AM
while you have it apart you might want to do the Neil clutch mod.
Post by: The norm on August 06, 2018, 08:25:28 AM
The 89 update is on the list also
